Forcing plugin tags to parse?
Hoosteeno's avatar
Hoosteeno
16 years ago
Hoosteeno's avatar Hoosteeno
Howdy-
I have a plugin that generates links based on the logged-in member id and group.
These links are being cached if template caching is turned on, so they show up for other members who shouldn’t see them.
Is there a way to force the parser not to cache my plugin’s output?
Justin
silenz's avatar
silenz
16 years ago
silenz's avatar silenz
I do believe embedded templates are not cached. So have you tried to just put your plugin into an embedded template?
