Hi there I am getting the following error message on one Weblog:
MySQL ERROR: Error Number: 1064 Description: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘AND f.group_id=w.field_group AND f.field_type=’cbox” at line 1 Query: SELECT f.field_id, f.field_name, f.field_pre_populate, f.field_pre_blog_id, f.field_pre_field_id FROM exp_weblog_fields AS f, exp_weblogs AS w WHERE w.weblog_id= AND f.group_id=w.field_group AND f.field_type=’cbox’
I’ve taken down then the template to as little as:
{exp:weblog:entries weblog="prem" orderby="date" sort="asc" limit="9999"}
{prem6}
{/exp:weblog:entries}And are still getting the problem. I do have the following extensions installed:
LG SAEF File Upload Multi Drop Down List (this is disabled) JQuery for Cpanel Foxee Extension User (v2.0.8) LG Live Look (this is disabled) LG Add Sitename LG Member Form Customiser Checkbox (v1.0.1)
I did have field frame installed but I thought that was the culprit and I deleted it and removed it from the server. Still no joy….
I’m on version 1.6.7. Any thoughts would be much appreciated.
Many Thanks Matt
