If you use the Structure module, install this extension and you will be redirected to the main Structure page whenever you save/update a weblog entry. Works great for sites manages exclusively(or mostly) from the Structure module.
Planned Enhancements: - Check that Structure is activated before activating itself - Create Structure tab for you if one doesn’t exist - Only redirect to Structure for weblogs that are assigned to Structure
Enjoy!
Hi there,
This is pretty good, thanks.
Is there any chance this extension could allow users to be re-directed straight to the ‘Structure’ tab of the control panel on login? Or certainly make that an option within the extension? (as not everyone might want this) I feel that my clients will be logging into the control panel with the sole purpose of using Structure so any way to remove a step or simplify this process would be great.
Stephen
By the way, I used this WI Direct extension in combination with removing the Publish/Edit tabs for the client Member Group, then hiding the My Account and Modules tab in the control panel using these extensions.
This has given me a really simple control panel with just a single tab. The last remaining step to ultra-simplifying the control panel would be for the CP Home page to be bypassed when logging in, and instead, to have the Structure tab appear as the first page they see after login. Not a major issue or anything of course! In fact, I might check out the Custom CP Home Panels extension in the meantime (or if this redirect isn’t possible) and just add some useful instructions/guidelines to that page instead.
sm9, How are you removing the Edit & Publish tabs? Anna
I did it via the built-in EE Member Group permissions - there’s a permission for Control Panel Area Access, and I removed Edit and Publish via that.
However, I later found that at least one of them (sorry, can’t remember which and I no longer have that install live) was required in order to use Structure so I ended up having to reinstate them.
