Structure Module Sub-Navigation Problem
JohnGribben's avatar
JohnGribben
16 years ago
JohnGribben's avatar JohnGribben
Hello,
We are using Structure for a client’s site that has a rather deep page hierarchy. Overall, it has been fantastic. I am currently having a problem, though, with the nav_sub tag. It functions perfectly for the first four levels of navigation, displaying only direct ancestors of the current page. But starting at level five, it starts to display children outside this direct lineage, and by level six a sort of site_map view appears, showing all pages descended from the top level.
I hope this makes sense.
Thanks, John
rockthenroll's avatar
rockthenroll
16 years ago
rockthenroll's avatar rockthenroll
This will be fixed in the next version. Thanks!
JohnGribben
16 years ago
Thank you! Again, this is brilliant work. It works quite well with this project.
Do you have any idea when the next version will be released?
John
rockthenroll
16 years ago
@JohnGribben Soon 😊 We’re dangerously close
JohnGribben
16 years ago
@rockthenroll, outstanding! Thanks!
Jason Morehead's avatar
Jason Morehead
16 years ago
Jason Morehead's avatar Jason Morehead
Heh, I just discovered this problem with a site I’m currently working on; I’m relieved to see that it’ll be addressed soon.
JohnGribben
16 years ago
Hello again,
I was wondering whether we could revive this thread. The site to which I originally referred last October is almost ready to launch (the client has entered their considerable amount of content). We purchased the upgrade to Structure, but the problem I posted appears to persist. Here is an example:
http://thecenter.ehclients.com/index.php/disease_information/asthma/what_is_asthma/
On this page, four levels down, the nav_sub tag (displayed in the left column) functions perfectly, displaying only direct ancestors of the current page. But if you drill down one more level, to “Definition of Asthma” for instance…
http://thecenter.ehclients.com/index.php/disease_information/asthma/what_is_asthma/definition_of_asthma/
…the nav_sub tag begins to display child pages outside this lineage.
I was informed that this would be fixed in the new version of Structure that we purchased. Is there a parameter I need to configure? I checked the new documentation, but I could not find anything that seemed to relate to this issue.
Thanks, John
rockthenroll
16 years ago
@JohnGribben Same type of resolute from a different issue. We’re working on a bug fix for this week. Hang tight!
Dom Stubbs's avatar
Dom Stubbs
16 years ago
Dom Stubbs's avatar Dom Stubbs
Coincidentally I’ve just run into this issue, on a site that we’re hoping to hand over to the client early next week. A fix this week would be such a big help. Much appreciate it.
JohnGribben
16 years ago
Thanks, @rockthenroll!
