Plugin: NB Cycle
Nicolas Bottari's avatar
Nicolas Bottari
16 years ago
Nicolas Bottari's avatar Nicolas Bottari
Based on a question I asked about looping through variables, I created the NB Cycle plugin, which lets you pass a variable, one by one, from a series of variables (i.e., “cycling” though a series of variables).
Useful for OR conditionals, passing tag parameters one after the other, etc. Example use:
{exp:nb_cycle parse="inward" values="whisky|tango|foxtrot"}
    {variable}
{/exp:nb_cycle}
will output:
whisky
tango
foxtrot
Parameters
parse=”inward” REQUIRED if you are using other plugins within the NB cycle tag pair.
values=”whisky|tango|foxtrot” The values to cycle through, separated by a pipe. Values can be anything: id numbers, weblog names, titles, etc. To pass variables containing a pipe (eg. 1|2, together), separate the variables with a comma “,”. eg. values=”1,2|3”
Single variable tag {variable} This tag will be replaced by the current cycle value set in values=”“
Another (more useful) example:
{exp:nb_cycle values="blog|products|catalog" parse="inward"}
    {exp:weblogs:entries weblog="{variable}"}
    {title}
    {/exp:weblog:entries}
{/exp:nb_cycle}
Mini-cycle I threw in a mini-cycle loop, as it might come in handy. Another set of variables can be looped within the {exp:nb_cycle} tag pair.
Example:
    <h2>{variable}</h2>
    <ul>
    {mini_cycle values="blog|products|catalog"}
    <li>{mini_cycle_variable}</li>
    {/mini_cycle}
    </ul>
{/exp:nb_cycle}
would output
<h2>whisky</h2>
<ul>
    <li>blog</li>
    <li>products</li>
    <li>catalog</li>
</ul>
<h2>tango</h2>
<ul>
    <li>blog</li>
    <li>products</li>
    <li>catalog</li>
</ul>
<h2>foxtrot</h2>
<ul>
    <li>blog</li>
    <li>products</li>
    <li>catalog</li>
</ul>
Single variable tag
{mini_cycle_variable} This tag will be replaced by the current cycle value set in values=”“
Documentation can be found here and example using conditionals is suggested in a previous forum post
NKT com's avatar
NKT com
16 years ago
NKT com's avatar NKT com
Fabulous! Just what i was looking for!
NKT com's avatar
NKT com
16 years ago
Would it be possible to support conditionals based on the variable name? So something like this would work?
{if segment_1=="{variable}"} class="current"{/if}
NKT com's avatar
NKT com
16 years ago
My mistake. they do work…
{if "{variable}"=="{segment_1}"} class="current"{/if}
Nicolas Bottari
16 years ago
Phew! Glad it worked out for you 😉 I was going to point out that
parse="inward"
might solve your problem.
Cem Meric's avatar
Cem Meric
16 years ago
Cem Meric's avatar Cem Meric
Very useful Nicolas, thanks.
