Tinybrowser not working all of a sudden
burkeb03's avatar
burkeb03
16 years ago
burkeb03's avatar burkeb03
I’m using Tinybrowser with TinyMCE and it seems that all of a sudden my Tiny Browser window is now just a blank white screen when I click the browse icon.
My client reports that this happened after attempting to upload a large file and it never recovered, but no server changes have been made (that I am aware of, of course), and I’ve restarted the server.
Any ideas?
Thanks, Brandon
Moved to Extensions Forum by Moderator
Sue Crocker's avatar
16 years ago
Hi, Brandon. TinyMCE and Tinybrowser are both third party add-ons. We don’t offer direct support for them.
I can offer general advice, though.
Clear your /system/cache files via FTP manually, leaving only only the index.html file.
Does that help?
burkeb03's avatar
burkeb03
16 years ago
Sue,
I understand about the support. Unfortunately that did not work for me. Still a blank screen after clearing /system/cache files and restarting.
16 years ago
Sending over to Extensions forum..
Max Lazar's avatar
Max Lazar
16 years ago
Max Lazar's avatar Max Lazar
Check the upload folder – the large file which was upload, is it here? It possible, that the TinyBrowser was uploaded file but after that script try to create a thumb and failed by not enough memory or max_execution_time. When you open TB windows again, first what TB doing – is check all thumbs and tried to create the new one. So, if the large file in folder, remove it. If it helps - increase memory_limit / max_execution_time.
burkeb03's avatar
burkeb03
16 years ago
Found large file. Removed large file. Increased memory_limit. All is well again.
Thanks Max!
