Plugin: Image Info
Jack McDade's avatar
Jack McDade
16 years ago
Jack McDade's avatar Jack McDade
Here’s a little plugin I’ve been using for photography sites. I’m sure some of this functionality has reared its head here and there in other add-ons, but if this helps someone, mission accomplished.
Image Info basically lets you pull file properties from all sorts of images and either display the info with set parameters, or lets you run conditionals on their values. A use case would be to change a template layout based on the image ratio – landscape/square/portrait. That sort of thing.
Example:
<pre><code> {exp:image_info image="http://example.com/images/image.jpg"}
    {if ratio == "landscape" || ratio == "square"}
        {embed="layouts/2_column"}
    {if:else}
        {embed="layouts/3_column"}
{/exp:image_info}[/code]
All the documentation is in the plugin, so you can read it in the Plugin Manager area.
Let me know if you have any questions!
OrganizedFellow's avatar
OrganizedFellow
16 years ago
OrganizedFellow's avatar OrganizedFellow
I’m hooked on using 960gs for my grid layouts. Your plugin will come in SO useful for me, Thanks Jack! 😊
Martin Luff's avatar
Martin Luff
16 years ago
Martin Luff's avatar Martin Luff
I could see some uses for that - thanks for sharing… 😉
Jason Morehead's avatar
Jason Morehead
15 years ago
Jason Morehead's avatar Jason Morehead
I’m running into a PHP error that only seems to occur when the plugin encounters BMP images:
Notice: Undefined index: channels in /home/goodbad/public_html/springboard/plugins/pi.image_info.php on line 101
Any ideas? Is there a potential workaround? Unfortunately, I don’t think there’s any way to prevent the site’s users from uploading the occasional BMP file even if I tell them not to.
