MSM not saving NSM Publish Plus settings
chairston's avatar
chairston
16 years ago
chairston's avatar chairston
I currently have 7 sites using MSM. When I set the group settings in NSM Publish Plus for the first 3 sites everything saves fine. Then when I try to save the settings for the 4th site; all the previous settings are reverted back to the default. What I am trying to do is give the Superadmin publisher right to all sites. Then each site will have a editor. I am using
ExpressionEngine 1.6.7 Build: 20090122 NSM Publish Plus (v.1.1.1) Multiple Site Manager Version: 1.1 Build: 20081024
Moved to the Extensions forum by Moderator
Sue Crocker's avatar
16 years ago
Welcome to the ExpressionEngine forums, chairston.
We don’t provide direct support for third party addons, so moving this to the extensions forum.
