New extension: Entry REEdirect
Derek Hogue's avatar
Derek Hogue
16 years ago
Derek Hogue's avatar Derek Hogue
My clients often get confused by the “preview” screen they come to after publishing or updating entries. Frankly, I do too. So here’s a fix for that.
Entry REEdirect is an ExpressionEngine extension that allows you to control, on a per-weblog basis, where authors land after publishing or updating entries in the ExpressionEngine control panel.
For each weblog you have three redirect location options for both new entries and updated entries:
  • Default Preview - EE’s built-in success screen with ugly entry preview
  • Publish Form - new entry screen for the same weblog you just published to
  • Manage Entries - the Edit tab, filtered to display entries from the weblog you just published to
  • 1.0.1 UPDATE: Edit Entry - keep editing the entry you just published or updated
In all cases the author will see a “success” message for their new entry or update, along with the entry’s title and an “Edit this entry” link.
The Extension Settings screen offers optional one-click setting of all of your weblogs to the same option for both new entries and updated entries. (This feature requires that jQuery for the Control Panel be installed loading jQuery 1.3 or newer.)
Entries submitted via SAEFs will be be unaffected by this extension.
Entry REEdirect has been tested on ExpressionEngine 1.6.8.
Download it from GitHub
Peter Lewis's avatar
Peter Lewis
16 years ago
Peter Lewis's avatar Peter Lewis
Nice. I know this was already done within another extension (maybe publish tweeks?), but it had loads of other tweaks that I didn’t need (and at the time clashed with Publish Page Improvements). This sounds perfect.
Thank you.
Derek Hogue
16 years ago
Glad to be of help. I wasn’t aware of Publish Tweaks, just had a look. A key difference here is that you’re in full control over where users are redirected in the case of both new entries and updates, and for each weblog.
Peter Lewis
16 years ago
Just been playing with it - very nice and flexible. Wish I’d had it a few days ago when I had to wade through editing loads of entries.
One future addition you might want to consider is to save and remain within the same entry…?
Thank you for releasing it.
Derek Hogue
16 years ago
That’s what Quick Save is for. 😊
Peter Lewis
16 years ago
I have Publish Page Improvements installed and Quick save turned off (keeps it simple) - see attached.
Publish Tweeks had that feature, so assume there’s a requirement from others for it.
Derek Hogue
16 years ago
Fair enough - just updated the extension to 1.0.1 to add this option.
Peter Lewis
16 years ago
LOL - fantastic!
Derek Hogue
16 years ago
As I’ve been working on a site with a lot of new entries today, the persistent “success” message on new entry screens began to bug me. So I just pushed a small update that disappears the success message after 5 seconds. (CP jQuery required.)
kasdesign's avatar
kasdesign
16 years ago
kasdesign's avatar kasdesign
This is really helpful. Thanks for releasing it. One of the sites I’m working on has a lot of categories within each weblog. Is there a way to set it so that filters to the category as well?
Peter Lewis
16 years ago
Kasdesign: You might want to try adding this extension as well: Edit Remember
Derek Hogue
16 years ago
Could be tricky, as you can assign multiple categories to a post, so how to decide which one to filter by? I second Twobelowzero’s endorsement of Edit Remember - it’ll fix this for you.
kasdesign's avatar
kasdesign
16 years ago
Thanks Twobelowzero! That’s just what I was looking for. Much appreciated!
kasdesign's avatar
kasdesign
16 years ago
Thanks for responding D-Rock. I figured it might be a bit tricky. The Edit Remember is perfect though. Thanks for your help and for your extension. Good stuff.
Derek Hogue
16 years ago
Just pushed version 1.0.3 to GitHub, which improves the display of the success message. It’s now a fixed overlay, so when it disappears the screen doesn’t shift. I also added a “close” link to the message.
1 2 3 Last
