Imgsizer not rendering at all
adro's avatar
adro
16 years ago
adro's avatar adro
Having a crazy problem here…I’ve great experience with Imgsizer in the past but for some reason it’s not working at all on the current site I’m working on. Everything looks fine:
{exp:weblog:entries weblog="photo-gallery" disable="trackbacks|member_data|pagination" orderby="date" sort="desc"}
    {exp:imgsizer:size src="{alt-image-upload}" width="141" alt="{title}"}
{/exp:weblog:entries}
And yet nothing renders…I tried it originally with FF Matrix + Ngen File and now I’m trying it with Mark Huot’s File with no success….
I’ve been up for like 16 hours…Am I missing something here?
Gareth Davies's avatar
Gareth Davies
16 years ago
Gareth Davies's avatar Gareth Davies
First guess is the src path may not be correct - do you get the correct path if you output {alt-image-upload} or view the source code of the page - what is the output?
adro's avatar
adro
16 years ago
adro's avatar adro
Yes… {alt-image-upload} outputs the correct path…
It’s almost acting as if the plugin is not installed…But I can confirm that it DEFINITELY is. This is too weird…
Gareth Davies
16 years ago
Does the images/sized directory have the correct permissions? Otherwise try using base_cache and changing to a directory you know has the correct permissions.
adro's avatar
adro
16 years ago
adro's avatar adro
Wow man, thank you so much…that seemed to do the trick!! Wasted so many damn hours…
Very much appreciated!
Ingmar's avatar
16 years ago
Ingmar's avatar Ingmar
Thanks for the assist, garethtdavies. I am still going to move this to “Plugins”, but I’m glad you solved it.
