LG Better Meta - CSS distortion issues
dsloan's avatar
dsloan
16 years ago
dsloan's avatar dsloan
I’ve installed LG Better Meta 1.8.0 but its appearance is all screwed up in the control panel. I’ve attached a few screenshots below. All other tabs and extensions/plugins are behaving fine. The extension itself seems at first glance to be working ok, it’s just the appearance that is broken. Using EE 1.6.8.
Anyone else found this, or suggest what may be wrong? Diarmid
dsloan's avatar
dsloan
16 years ago
Can I be the only person seeing this problem? Has anyone else seen it, even if it hasn’t been resolved?
Diarmid
dsloan's avatar
dsloan
16 years ago
I have upgraded to LG Better Meta 1.8.1, but the problem persists. Thought it may have been related to stylesheets related to Tiny MCE but doesn’t appear to be.
vacquah's avatar
vacquah
16 years ago
vacquah's avatar vacquah
I am having the same issue after upgrading to 1.9. Sent an email to Levi … let me know if you found a solution to this.
dsloan's avatar
dsloan
16 years ago
Yes, sorry, should have posted the solution here. Leevi pointed out that LG Better Meta does not support the Classic CP them. You need to use the Default theme.
vacquah's avatar
vacquah
16 years ago
I am using the default theme …
dsloan's avatar
dsloan
16 years ago
Hmmm… don’t know then. That was what the problem was for me.
Leevi Graham's avatar
Leevi Graham
16 years ago
You can use LG Better Meta 1.9.0 usig the classic theme. Just copy the included them folders in to “classic” rather than “default”
IJsbeer's avatar
IJsbeer
16 years ago
IJsbeer's avatar IJsbeer
I’m using the default theme and have the same css-disorder as dsloan..:(
Leevi Graham
16 years ago
Hey guys, Grab the latest download (it’s just a build update) and follow the installation instructions. It should fix any issues.
IJsbeer's avatar
IJsbeer
16 years ago
Hi Leevi,
I did that, but the style in the controlpanel (default) is still a mess. In the extensionspanel (settings) and in the tab for edit/publish entry. It’s not a big problem, all the fields etc are accessible, but the eye complains…:)
Latest build EE 1.68 and Better Meta 1.90… Fresh install etc.
Marcel
IJsbeer's avatar
IJsbeer
16 years ago
I moved my website to another server…. problem solved. Don’t know why, but I accept it…:)
Marcel
