Plugin: MX Mobile Devices Detect (EE 1.6x / EE 2.x )
Max Lazar's avatar
Max Lazar
16 years ago
Max Lazar's avatar Max Lazar
MX Mobile Detect is a small and simple plugin detect is template was request by Mobile Device or no. It’s just an initial release. So that feature requests & bugs report welcome.
Place the following tag in your templates (it would be better if your place it close to the header);
{exp:mobile_detect location="http://m.site.com/"}
“location” - is your url for mobile devices for redirect
Or you can use that way (without redirection(at this moment)):
{exp:mobile_detect}
{if mobile}
Is mobile device
{/exp:mobile_detect}
download
Max Lazar's avatar
Max Lazar
16 years ago
Sorry! Wrong category. pls. move it into plugins. Thanks!
Ingmar's avatar
16 years ago
Ingmar's avatar Ingmar
Moved as per request.
wecreateyou's avatar
wecreateyou
16 years ago
wecreateyou's avatar wecreateyou
This little thingy just made life a little sweeter. Downloaded and testing. Thanks for sharing it!
onepanman's avatar
onepanman
16 years ago
onepanman's avatar onepanman
Does not seem to recognize an iPod Touch as mobile. Is this intended? Blackberry worked though.
Todd D.'s avatar
Todd D.
16 years ago
Todd D.'s avatar Todd D.
You might modify the plug-in by adding
"ipod",
in the array after iphone.
I’m not sure if that will work because I have no ipod touch to test with.
Max Lazar's avatar
Max Lazar
16 years ago
"ipod",
you right onepanman you can download the version with ipod from the doc page
Max Lazar's avatar
Max Lazar
16 years ago
Release v2.1 - compatible with EE 2.x.
outline4's avatar
outline4
16 years ago
outline4's avatar outline4
Hi there, I was wondering if this is compatible with MSM?
cheers stefan
Max Lazar's avatar
Max Lazar
16 years ago
I don’t see any problem using MX Mobile Devices Detect with MSM. Plugins usually more dependent from template than from site.
outline4's avatar
outline4
16 years ago
thanks for the quick info! I had the same thought, but on devot-ee MSM is crossed, so I thought I double check! thanks stefan
dsong1's avatar
dsong1
16 years ago
dsong1's avatar dsong1
Added this to my homepage. Works great! Did have a question though…
What would be the best way to switch back to full site? In other words, if you have been redirected to a mobile site and have a “VIEW STANDARD SITE” link, how would you tell it not to redirect… hope that makes sense.
NCangler's avatar
NCangler
16 years ago
NCangler's avatar NCangler
Any plans to make an EE 2.0 version? I could use this on a 2.0 site we are developing now, if you needed a place to test it I be happy to do that 😊
Max Lazar's avatar
Max Lazar
16 years ago
😊 you can download both versions on my ext. page.
If you will have any problem - just send me a note and I will help you asap.
NCangler's avatar
NCangler
16 years ago
😊 you can download both versions on my ext. page. If you will have any problem - just send me a note and I will help you asap.
Ah man….missed that the first time. Thanks!
1 2 3
