I’m currently experiencing a very strange issue where byplugin parameters are not being passed (or visible at all) to the plugin.
I’ve written a simple plugin with the following structure:
{exp:vc_plugin:archive_widget weblog="page" site="1" category="2"}
{/exp:vc_plugin:archive_widget}with the following code in pi.vc_plugin.php (abstracted for clarity):
function archive_widget() {
global $DB, $TMPL;
$weblog = $TMPL->fetch_param('weblog');
$cat_id = $TMPL->fetch_param('category');
$site_id = $TMPL->fetch_param('site');
$tagdata = $TMPL->tagdata;
print "<pre>" . print_r($TMPL,1) . "</pre>
<p>”;</p>
<p>…print_r output (abstracted for clarity):
[4] => Array
[tag] => {exp:vc_accountis:archive_widget weblog="blog"}
[class] => vc_accountis
[method] => archive_widget
[tagparts] => Array
[0] => vc_accountis
[1] => archive_widget
[params] => Array
[weblog] => blog
...As you can see, it’s not seeing the site or category parameters…
I have saved the template as a file, reopened in EE and saved via the CP, deleted all system/cache etc etc.
Any ideas! This one has got me stumped! (and yes, I am definitely editing the correct file)
Thanks in advance
M
