FieldFrame extension broke EE!
mpechicago's avatar
mpechicago
16 years ago
mpechicago's avatar mpechicago
I installed and enabled the FieldFrame extension. Upon enabling I get this error on any and every admin page:
MySQL ERROR:
Error Number: 1146
Description: Table ‘coffee.exp_ff_fieldtype_hooks’ doesn’t exist
Query: SELECT * FROM exp_ff_fieldtype_hooks
If I disable all extensions via the config.php file it works again, however I don’t know how to manually disable FieldFrame extension only. Right now it’s all disabled or broken EE.
Any help is appreciated. Thanks.
16 years ago
I’m not up on the extension- can you disable the specific extension in ‘Admin- Utilities- Extensions’?
Also- shifted this down as it’s definitely third party related. Might be good to get everything working with extensions entirely disabled. Then go through any extensions and get them squared away individually.
mpechicago's avatar
mpechicago
16 years ago
It seems everything is working properly now, Whew! Thank you for your help.
I am still receiving this error when enabling all extensions from the config file.
I seem to have boxed myself in: when I enable ‘allow_extensions’ to “y” it also enables the FieldFrame extension. The error appears any time the FieldFrame extension is enabled. With only seeing this error in EE, I have no way to disable ONLY FieldFrame, and remove it. I can only get EE working again by going into the config file and setting ‘allow_extensions’ to N, which disables extensions, and also removes my ability to enable individual extensions again. It’s none or all.
mpechicago's avatar
mpechicago
16 years ago
Fixed. Had to go into phpMyAdmin and manually delete all references to fieldframe, then reinstall. Works fine now.
16 years ago
Argh- but very glad you got it working!
