Structure Module Bug
Sundara Pandian's avatar
Sundara Pandian
16 years ago
Sundara Pandian's avatar Sundara Pandian
I have completely installed the Structure module in ExpressionEngine regarding this http://buildwithstructure.com/ instruction. But i can not see the Structure Tab in Admin side. Eventhough installed successfully the structure extension, modules and css.
Can any one help it for me?
Thanks, Sundar. ([email protected])
Sue Crocker's avatar
16 years ago
Welcome to the ExpressionEngine forums, Sundar.
We don’t provide direct support for third party addons, so we’ll be moving this to the Modules forum.
Sundara Pandian
16 years ago
Hi Sue Crocker,
Thank you so much for your quick response.
Right now i configured successfully the Structure module in EE. But the Structure module is third-party add-on. So if i use this in my site, Is arise any problem in future?
Can you reply me for this?
Thanks, Sundar.
16 years ago
With third party add-ons, the EE team doesn’t directly support bugs with the additions or configuration issues, etc. If we have the add-on and/or are familiar with it, we’ll definitely chime in. But such is not always the case.
Any problems/questions with the core EE code are still our domain (though it doesn’t hurt to give us a ‘heads up’ if a third party addition might be having an effect). And we’re always happy to help if we can- we just can’t support all of the additions out there. That’s best left to the author of the third party add on.
Hope that helped clarify things.
16 years ago
I honestly can’t say. I’ve never used it, so I have no first hand knowledge. What I do know is that 95% of the addons that are third party work just fine, and I make it a point to follow any threads regarding modules I rely on.
For instance, I use Solspace’s Freeform module on almost every site I develop. I read their forum on a semi-regular basis, because I want to keep up on what’s happening with the module.
I also use FieldFrame and have made one extension for it, so I try to keep up with that addon too.
Getting back to the Structure module, do what I do. 😊 Does that help?
rockthenroll's avatar
rockthenroll
16 years ago
rockthenroll's avatar rockthenroll
@Sundara Pandian you have to go to Modules » Structure and then click “New Tab” in the top right of your CP. This is the same for any new tab you’d like to add to your CP.
