LG Better Meta and the Pages Module
Marcus Hodges's avatar
Marcus Hodges
16 years ago
Marcus Hodges's avatar Marcus Hodges
Hi. I have some entries that use the Pages Module to retain their old .html-based URL structure.
For example, the template/entry http://site.com/main/entry becomes http://site.com/main/entry.html through use of the Pages Module.
I want to be able to use LG Better Meta on these pages, but can’t figure out the syntax. I can use the following tag to show the page before the Pages Module puts its stamp on it, but that’s not the link people are going to be calling as it isn’t referenced in the site anywhere.
{exp:lg_better_meta_pl:template url_title="{segment_2}"}
When the URL is http://site.com/main/entry, I get the results of the LG Better Meta plugin doing its magic. When the URL is http://site.com/main/entry.html, I do not.
Can anyone help me figure out how to resolve this?
Marcus Hodges
16 years ago
Can anyone suggest a more appropriate place to ask questions like this? I can never seem to get an answer from within this forum, but don’t want to put things in the wrong categories.
Lisa Wess's avatar
16 years ago
Lisa Wess's avatar Lisa Wess
You might try emailing the author if you’re not getting a response in the forums.
Leevi Graham's avatar
Leevi Graham
16 years ago
Hi Marcus,
That’s an interesting problem. I would recommend using a weblog:entries tag to grab the entry_id and pass that to the extension directly. If you have caching turned on and disable all of the params it will be a pretty light weight call.
I personally wrap the main portion of a single entry page in single weblog:entries tag. The page will break if the entry is not found becuase the header won’t be included. This isn’t really a concern when you use require_entry = “yes” and {if no_results}. I’ve added an example below of a fairly simple and standard blog post.
You’ll also notice that I’m setting the “meta_title_suffix” param which adds a little more SEO to the title.
{assign_variable:this_page_weblog="blog"}
{exp:weblog:entries
    cache="yes"
    disable="category_fields|member_data|pagination|trackbacks"
    dynamic="off"
    limit="1"
    refresh="10"
    require_entry="yes"
    rdf="off"
    status="not closed|Pending"
    weblog="{this_page_weblog}"
    url_title="{segment_3}"
    {if no_results || segment_2 != "post"}{redirect="404"}{/if}
    {embed="_includes/.head"
        entry_id="{entry_id}"
        meta_title_suffix="{blog_title}"
    <div id="content">
        <div class="copy">
            <h1 class="page-title">{title}</h1>
                {entry_date format="%d:%m:%Y"} |
                {categories}<a href="/blog/category-archive/#cat-{category_url_title}">{category_name}</a> + {/categories}
            {blog_body}
        </div>
    </div>
{embed="_includes/.foot"}
{/exp:weblog:entries}
Leevi Graham
16 years ago
A quick follow up. If you need to include other {exp:weblog:entries} tags on the page you can unbalance the first {exp:weblog:entries} tag like so:
cache="yes"
    dynamic="off"
    limit="1"
    refresh="10"
    require_entry="yes"
    rdf="off"
    <div id="content">
        <div class="copy">
            {blog_body}
        </div>
    </div>
<ol>
{exp:weblog:entries weblog='some_other_blog' dynamic='off'}
    <li>{title}</li>
</ol?>
</code></pre>
Again you’re guaranteeing an entry so the unbalanced tags don’t really matter.
Marcus Hodges
16 years ago
What code do you have living inside the _includes/.head template? That might get me a little closer to understanding. Thanks much.
Marcus
Leevi Graham
16 years ago
checkout the section on embedding headers in the howto section: http://leevigraham.com/cms-customisation/expressionengine/lg-better-meta/
Marcus Hodges
16 years ago
This is kind of above my head. I think we’ll just put our meta stuff in regular ol’ templates for now and call it a day.
kenny2's avatar
kenny2
16 years ago
kenny2's avatar kenny2
Leevi, should that just be “title_suffix” ? I cannot find “meta_title_suffix” in the embedded template
