FLV Player
2techchicks's avatar
2techchicks
16 years ago
2techchicks's avatar 2techchicks
I’m having trouble getting a video to play on my site. I installed the FLV player plugin from 5pieces.com (v2.1).
This is the code that’s in my template:
{exp:flvplugin playerpath="images/uploads/Title_pro_disc-L.swf" playernumber="1" file="images/uploads/Title_pro_disc-L.flv" width="351" height="284" showdigits="true"}
I uploaded the ufo.js file to my root EE directory and added the script into the head tags.
It’s giving a message that says “stream not found”. http://www.sdspineinstitute.com/cms/index.php
Any ideas??
V 1.6.7
Lisa Wess's avatar
16 years ago
Lisa Wess's avatar Lisa Wess
Try adding a slash before images in both playerpath= and file=. You need absolute paths in there, building off the root.
2techchicks
16 years ago
Thank you. I tried that, but nothing displays. I also tried entering the full path http://…
Mark Bowen's avatar
Mark Bowen
16 years ago
Seems to me like that file doesn’t even exist in that location perhaps?
http://www.sdspineinstitute.com/images/uploads/Title_pro_disc-L.swf
That would be where it’s trying to find it. Are you sure it’s actually located there?
Best wishes,
Mark
Mark Bowen's avatar
Mark Bowen
16 years ago
Actually ignore that I can see where your file is now and you will probably just need to do this sort of thing instead :
{exp:flvplugin playerpath="/cms/images/uploads/Title_pro_disc-L.swf" playernumber="1" file="images/uploads/Title_pro_disc-L.flv" width="351" height="284" showdigits="true"}
Best wishes,
Mark
2techchicks
16 years ago
Thanks, Mark. I tried that code, but it went back to giving the stream not found message. I’m going to upload a different video and see if that makes a difference.
Lisa Wess's avatar
16 years ago
You need to apply the same concept that Mark applied to the playerpath= to the file=.
{exp:flvplugin playerpath="/cms/images/uploads/Title_pro_disc-L.swf" playernumber="1" file="/cms/images/uploads/Title_pro_disc-L.flv" width="351" height="284" showdigits="true"}
2techchicks
16 years ago
Thank you. It seems there was an issue with the video that I was working with. I tried a different one and it works perfectly. Thanks for your help! 😊
Mark Bowen's avatar
Mark Bowen
16 years ago
Well the stream not found message is another issue 😉
I am guessing that the .swf has the stream path hard-coded into it maybe?
If so then check the path in the Flash file and make sure it is correct.
Saying that I just checked the page again and using the Activity Window in Safari it is saying that this file :
http://www.sdspineinstitute.com/cms/images/uploads/Title_pro disc-L.flv
is missing. Might be something else you need to sort out too perhaps? Seems you have a space in the name instead of the required underscore.
Best wishes,
Mark
2techchicks
16 years ago
More questions about this player. I used a different video, which is working now. My code:
{exp:flvplugin playerpath="/cms/images/uploads/Title_0101.swf" playernumber="1" file="/cms/images/uploads/Title_0101.flv" width="351" height="284" showdigits="true" autostart="false" repeat="false"}
  1. The autostart is set to false, but the video starts up every time you open the page.
  2. Why does the player have a “buy now” link on top of the video?
2techchicks
16 years ago
I think I answered the second question already - I need to buy a commercial license.
