better meta help tutorial?
bmovie's avatar
bmovie
16 years ago
bmovie's avatar bmovie
hi, I buy better meta and Iam so cofused of how use:
I add this line inside the <head> {exp:lg_better_meta_pl:template} </head> that head are in a embed called “document”
so I active tab better meta on publish form….
I add the title etc… and I dont any results on entries… :(
when works I need add for any entrie the title… keywords etc… ???
any tutorial of how customize, I dont understand well the official documentation (just the xml site maps)
thanks , help please!
Cem Meric's avatar
Cem Meric
16 years ago
Cem Meric's avatar Cem Meric
passing url_title info with it might help
i.e.
url_title="{segment_2}"
bmovie's avatar
bmovie
16 years ago
thanks Cem, more info for know what is segments? or more about better meta for works really well??? help please I cant use better meta :(
Cem Meric's avatar
Cem Meric
16 years ago
First of all, if you haven’t gone through the documentation I would highly recommend reading it.
Referring to my example, lets say you have the following url structure
domain.com/news/news_item
which equals to
domain.com/segment_1/segment_2
and considering you have the extension installed correctly with meta details entered in your weblog entry, using below code in the header will bring necessary meta details
{exp:lg_better_meta_pl:template url_title="{segment_2}"}
