Issue with Structure not saving settings
Hollywood's avatar
Hollywood
16 years ago
Hollywood's avatar Hollywood
I’ve used the Structure plugin before and never has this problem, but each time I log in as a super admin, I have to visit the Structure settings and re-set the weblog type (Structure) and Default Template so the Structure tab will show up when I publish a new page or edit an existing page.
The message that appears on the settings page is as follows:
No permissible groups exist. A group must have these permissions before it will show here. * Can access control panel * Can access publish * Can access edit * Can access Structure
I’m logged in as a super admin though. Anyone ever seen this issue? Can it be fixed?
idawgik's avatar
idawgik
16 years ago
idawgik's avatar idawgik
Been running into the same problem on a site I just started development on now. You can actually save the settings, but shortly after, it resets.
I’ve been able to verify that the settings are actually saved in the exp_structure_settings table, but the entries get removed, it looks like when you to the structure module page again.
I haven’t been able to find any particular cause of this issue, using the latest versions of structure and EE.
Only solution I’ve found so far is to totally uninstall the site and start over.
Nick Kutateli's avatar
Nick Kutateli
16 years ago
Nick Kutateli's avatar Nick Kutateli
I’ve ran into this issue with the current site I’m building out. Has anybody found out what causes the problem?
idawgik's avatar
idawgik
16 years ago
I did actually get this resolved in the main Structure thread. Basically, what happened was, I added a tab to the structure page after updating the settings the first time. Consequently, the url for the tab had the additional variables in it telling structure to reset every time I clicked on the tab. Verify that you create the tab after going to the main structure page from the modules area, that should resolve it.
