New Extension: MCImageManager field for FieldFrame
sambo's avatar
sambo
16 years ago
sambo's avatar sambo
Just a quick and dirty FieldFrame field for MCImageManager.
I hope someone can use it and even develop it further. I don’t consider it production quality as I haven’t tested it and it is my first extension. I guess LG will eventually make a FF version of his great LG Image Manager field so this won’t be needed.
I will however most likely change this to use my own file manager that I am developing - whenever I have some free time 😉
Download
eyevariety's avatar
eyevariety
16 years ago
eyevariety's avatar eyevariety
Cool, I am going to take a swing at making it work with one of the opensource/free (KFM?) alternatives when I get a chance.
Many folks are talking about file/image managment in EE and FF. I expect we will see some nice stuff in this area- thanks for moving it along. Thanks
sambo's avatar
sambo
16 years ago
Great,
it should be super easy to get this to work with any filemanagement gadget.
Best of luck, Sammi
smartpill's avatar
smartpill
16 years ago
smartpill's avatar smartpill
Excellent. Just dropped it in and seems to work fine so far. I was hoping someone would take this on. What makes you say it’s not “production quality”? Any potential bugs that you’re aware of or just being cautious?
sambo's avatar
sambo
16 years ago
yes I am being cautious as I am not an experienced extension developer and am not aware of possible pitfalls when the extension is upgraded for an example, settings field changed and such. I just haven’t investigated it well enough to be confident.
However - the functionality is so simple that there is really not much room for problems so it might work just fine.
I was thinking about changing it so that the CP would display the thumbnail generated by MCI Imagemanager but I haven’t done it yet because the user actually has a lot of control over where the thumbnails are located and renamed. So I would have to take that into account in the plugin. I haven’t worked out a decent way to do that.
Best, Sammi
smartpill's avatar
smartpill
16 years ago
Fair enough. 😉
That would be really helpful especially when used for photo galleries – considering the “less than descriptive” file naming my clients tend to use.
Thanks again.
Dan Lovejoy's avatar
Dan Lovejoy
16 years ago
Dan Lovejoy's avatar Dan Lovejoy
I can’t get this one or LG Image Manager to work at all. When I browse directly to the MCImageManager (at a URL like this one): http://www.mydomain.com/path/to/manager/imagemanager/pages/im/index.html?domain=alamode.com
Everything is fine.
When I open the ImageManager from within EE, it never finds the folders I’ve specified in the config. The ImageManager loads, but it keeps loading and loading forever,never pulling up photos. Firebug says it’s looking for: http://www.mydomain.com/path/to/manager/imagemanager/js/../index.php?type=im&page=index.html&domain=alamode.com
When I copy and paste that URL into the browser bar, it redirects to the URL above and works fine.
I have the path configured correctly and the config.php seems to be working standalone, so I’m at a loss and very discouraged. Any ideas?
Thanks, Dan
Update: To clarify - It doesn’t matter if I use Sambo’s FF extension or Leevi’s LG Image Manager, the result is the same.
Update: I’m befuddled, but now this seems to be working. It’s popping up in a new window and it seems to work just fine. Not sure what changed.
