hi, I buy better meta since 2 days ago… I download from your site lg-better-meta.1.8.0.commercial.zip I running EE 1.6.7 I copy the files again! I active, I put this line between HEAD… {exp:lg_better_meta_pi:template} I check my site and I receive this error!
Error The following tag has a syntax error: {exp:lg_better_meta_pi:template} Please correct the syntax in your template.
What happend! please I need urgent! use better meta! and continue with my site, please.
hi, I buy better meta since 2 days ago… I download from your site lg-better-meta.1.8.0.commercial.zip I running EE 1.6.7 I copy the files again! I active, I put this line between HEAD… {exp:lg_better_meta_pi:template} I check my site and I receive this error!Error The following tag has a syntax error: {exp:lg_better_meta_pi:template} Please correct the syntax in your template.What happend! please I need urgent! use better meta! and continue with my site, please.
I had this too, and scoured your code Leevi, but after a while remembered something about you having changed an extension filename from _pi to _pl (I forget the exact details now, my work/bier ratio is drastically shifting towards the latter!), and thus if you do this:-
{exp:lg_better_meta_pl:template}(Note the change from i to l)
…it all works again. Perhaps the docs need updating on the site?
thanks baboonbrand now works with {exp:lg_better_meta_pl:template}
I see that problem, some extensions and plugins are out of date! on lg site, I dont know why… that makes confused things between people that buy and use his products.
so now works that the problem LG? is good use {exp:lg_better_meta_pl:template} whats the difference?
