Equivalent of tweetmeme
artlab's avatar
artlab
16 years ago
artlab's avatar artlab
I am wondering if anyone has developed the equivalent of tweetmeme for Expression. Specifically I want to create a button that says ‘tweet this’ The user click on the button and it links to the clickers twitter page (if they have one) and enters the info with a bitly shortened URL, all ready to go
So basically it generate a link like:
http://twitter.com/home/?status=RT+@fireuser+FireUser+Blog:+Top+ten+tips+for+CAD+workstation+tuning+http://bit.ly/Tr8rI
Any plug-ins like this? Or has anyone written any cod that can do this (essentially put ‘+’ symbols between title words, and convert the permalink to a bitly URL
chrispiciullo's avatar
chrispiciullo
16 years ago
chrispiciullo's avatar chrispiciullo
Have you taken a look at this plugin: Tweet This? Looks like it does exactly what you need.
artlab's avatar
artlab
16 years ago
Perfect - exactly what I was looking for.
Linda A's avatar
Linda A
16 years ago
Linda A's avatar Linda A
Does this plugin still work? I installed it and put it into a template, but then the template came up blank.
