BBM Decimal Entities
BackBeat Media's avatar
BackBeat Media
16 years ago
BackBeat Media's avatar BackBeat Media
Hi All,
Does anyone know of a plugin that would convert html special characters into their unicode equivalent?
  becomes
I’m currently using the exp://xml_encode plugin but that converts
  to
which MacSurfer’s feed parser chokes on.
I’m happy to write the plugin myself, I just wanted to make sure I’m not duplicating work… my searches have turned up nothing so far.
BackBeat Media
16 years ago
I have created this plugin, and have put it up on github.
http://github.com/tmoswift/bbm_decimal_entities
