LG Twitter give problem with FieldFame extension
bmovie's avatar
bmovie
16 years ago
bmovie's avatar bmovie
maybe somebody happend the same, the LG Twitter is great, but! first when I install the forum module I need desactive lg twitter for forum work… ok no problem but with FieldFame extension Matrix cels just show me 1 row, the + plus dissapear completly.
any have same issue?
thanks
John Henry Donovan's avatar
16 years ago
John Henry Donovan's avatar John Henry Donovan
Bmovie,
I am going to move this to the Extensions forum for you as it looks like a conflict with the extension itself. You could also try contacting the author himself.
Leevi Graham's avatar
Leevi Graham
16 years ago
This is no doubt a JS issue. Unfortunately I don’t have time to debug it at the moment (finance is having a baby ay day now) but I’ll take a look when I get a chance.
pirco's avatar
pirco
16 years ago
pirco's avatar pirco
confirming the issue: extension conflict between LG Twitter (v.2.0.1) and FieldFrame (v.1.2.0)
can’t add additional rows to “FF matrix” in the publish form AND can’t add additional matrix cells in the “add/edit custom weblog field” interface.
no JS errors being reported and one (the first) row of the matrix still works. just can’t add new ones.
Joobs's avatar
Joobs
16 years ago
Joobs's avatar Joobs
Was this problem fixed?
I’ve just tested out LG Twitter and I can’t add the rows to a FF Matrix. It’s been a while since I updated field frame though.
Nutmeg's avatar
Nutmeg
16 years ago
Nutmeg's avatar Nutmeg
Joobs, head over to Brandon Kelly’s site and update Fieldframe to 1.3.3 (while you are there check out Wygwham (worth all the tea in China)). If the problem persists you could find the latest version of LG Twitter at http://github.com/leevigraham. If this doesn’t fix the issue start turning off other extensions…
Joobs's avatar
Joobs
16 years ago
The latest version on github seems to have fixed the issue (http://github.com/newism/lg.twitter.ee_addon/tree/master)
This version is newer than the one on Leevis site.
