I’m using a Countdown plugin to countdown for the launch of a website, using the output below:
{exp:countdown day="7" month="07" year="2009" hour="16" event="Launch"}I have been trying to incorporate minutes in to the countdown as the launch is 16.30, so the obvious solution was minutes=”30” which didnt seem to work nor did any other alternate methods that I could think of.
Any help or suggestions would be appreciated
{exp:countdown day="7" month="07" year="2009" hour="16" event="Launch"}I have been trying to incorporate minutes in to the countdown as the launch is 16.30, so the obvious solution was minutes=“30” which didnt seem to work nor did any other alternate methods that I could think of.
Hiya,
If this is the countdown plugin from this page here then currently the plugin doesn’t have a minutes=”“ parameter. The plugin would have to be modified in order to have one.
Best wishes,
Mark
You might like to check out this plugin here 😉
Was very quickly put together so hopefully should work as advertised but if not then just let me know and I’ll take a look at whatever problems might arise.
Best wishes,
Mark
