Solspace Rating Problem
s707's avatar
s707
about 17 years ago
s707's avatar s707
I use the following code:
{exp:rating:stats entry_id=”{entry_id}” precision = “2” theme=“default”}{overall_avg}{/exp:rating:stats}
The rates are shown as 5.00, however if an article does not have any rate - an empty place appears, but I would like it to be 0.00, how can I do it?
[Mod Edit: Moved to the Modules: Discussion and Questions forum]
Arun S.'s avatar
Arun S.
16 years ago
Arun S.'s avatar Arun S.
First, Solspace has their own support forums. For matters like these, I’d suggest you post there. You’ll probably get more informed answers. The documentation is good too.
But this one, I can answer. 😊 What I would do in this instance is to use a conditional to test how many rating there are. If there are none, display “0.00”, otherwise show the average. So, something like this:
{exp:rating:stats entry_id="{entry_id}" precision="2" theme="default"}
{if overall_count == "0"}
  0.00
{if:else}
  {overall_avg}
{/exp:rating:stats}
s707's avatar
s707
16 years ago
s707's avatar s707
Thanks, but it doesn’t work…
BC Team's avatar
BC Team
16 years ago
BC Team's avatar BC Team
Looking at using the Rating Module and am searching for live examples but found this thread.
I think the code may need to be, i’m just guessing:
{if overall_count == ""}
OR
{if overall_count == "null"}
OR something like that - Did you get it to work?
Narthex's avatar
Narthex
16 years ago
Narthex's avatar Narthex
The stats tag doesn’t seem to show at all if there is not any data. The following does work, though. Make sure it is not within any tags. It can stand on its own.
Yuri's avatar
Yuri
16 years ago
Yuri's avatar Yuri
quote from Solspace forum on this issue:
Rating:Stats will return absolutely nothing if there’s no results. You’ll need to use the {if no_results}0{/if} conditional if you wish to display something in the event there’s no ratings for an entry. smile Keep in mind though, if you have the Rating:Stats loop inside of a Weblog:Entries loop, it will override the conditional and it wont work, so you’ll need to put the Rating:Stats code inside an embed instead.
