DC Template Manager: Bulk-manage ExpressionEngine Templates
gridonic's avatar
gridonic
17 years ago
gridonic's avatar gridonic
Hey Guys
Have you ever messed around with your EE templates stored in the database AND on the file-system? Ever renamed or moved those without opening the database version to “sync-back”? Ever had to move an EE installation to another server and you were using “saved” templates?
With this module, you can:
• Bulk-save “as file” your entire template structure or selected templates
• Sync back file-system versions of templates to the database
• Bulk-delete all “saved” templates from your file-system
Official Website: http://www.designchuchi.ch/index.php/blog/comments/dc-template-manager
As always, keep backups of your database and files if you’re deleting something. If you find any bugs, don’t hesitate to report them.
Enjoy!
Sean C. Smith's avatar
Sean C. Smith
17 years ago
Sean C. Smith's avatar Sean C. Smith
This module kicks ass. I used it in beta and within 5 minutes of installing it added it to my must have for all future builds.
Ruud L. Heerkens's avatar
Ruud L. Heerkens
17 years ago
Ruud L. Heerkens's avatar Ruud L. Heerkens
Hello,
I downloaded and installed this .mod in a development enviroment running in a sub directory. Now when trying to update the Files -> DB it returns an error:
MySQL ERROR: Error Number: 1054 Description: Unknown column ‘item_author_id’ in ‘field list’
Manually updating the ‘old fashion way’ works just fine.
Any ideas ?
