Help- Lg Better Meta Plugin- Do I have to reinstall EE to get this running?
brandaid's avatar
brandaid
17 years ago
brandaid's avatar brandaid
I just added/installed the LG Better Meta plugin to my clients’ site. I enabled it in the extensions manager, but do not see any change to the control panel. Am I missing something, or does EE have to be re-installed for this to operate? If I re-install, is there a way to preserve the module applications already in use?
Thanks for your assistance…
Walker Hamilton's avatar
Walker Hamilton
17 years ago
Walker Hamilton's avatar Walker Hamilton
You don’t need to reinstall anything! Go and edit a post or create a new post and you should see a tab called “Better Meta” in the row of tabs for the entry content.
brandaid's avatar
brandaid
17 years ago
The Better Meta tab is not there… I just installed the Structure module as well and that tab shows up when publishing/editing posts. Is there another ‘enable’ step beyond the Extension Manager settings? Could Better Meta be enabled AND incorrectly installed?
Thanks again!
brandaid's avatar
brandaid
17 years ago
I figured it out! I needed to go into ‘settings’ and tell it which blogs to show up for :p
Peace out!
