I have seen a similar post unanswered, so I figured Id throw up a new thread with more details.
Issue: Enabling the LG Data Matrix 1.1.1 extension.
When I try to enable the extension, i get the following PHP error:
MySQL ERROR:
Error Number: 1064
Description: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'WHERE Field = 'lg_field_conf'' at line 1
Query: SHOW COLUMNS FROM `exp_weblog_fields` WHERE Field = 'lg_field_conf'It would be great to figure out what’s going on, the extension looks incredible and there are surely others out there with my issue.
MySQL ERROR:
Error Number: 1064
