LG TinyMCE problem
7tim's avatar
7tim
17 years ago
7tim's avatar 7tim
Hello,
I’ve installed the LG TinyMCE 1.3.0 and followed every steps from http://leevigraham.com/cms-customisation/expressionengine/lg-tinymce/
I have TinyMCE as it is required. But still it’s not working when I try to write a blog post. I can see the custom field, but it doesn’t show a wysiwyg editor. The settings from LG TinyMCE and the path to TinyMCE is correct.
Can anybody help? Thanks in advance,
Moved to Extensions: Discussion and Questions by Moderator
7tim's avatar
7tim
17 years ago
7tim's avatar 7tim
Anybody any hints for solving this problem?
just tried this one:
http://www.electricputty.co.uk/epeditor/?p=27
All seems to be set OK, but we can’t see the buttons when we try to publish…
HELP
Jon Thomas's avatar
Jon Thomas
17 years ago
Jon Thomas's avatar Jon Thomas
Double check your directory paths in the extension settings. Make sure it points to the exact path that you uploaded the extension to. That’s what happened to me.
