Inserting uploaded images and documents into EE posts through TinyMCE editor
hssweb's avatar
hssweb
17 years ago
hssweb's avatar hssweb
We’ve recently set up certain EE posting forms to use the TinyMCE WYSIWYG editor. However, one then encounters problems accessing and posting images and documents through this editor.
The page
http://expressionengine.com/wiki/TinyMCE_and_ExpressionEngine_Integrated_File_Upload_Management/
discusses a method of using additional templates and a reference to external_image_list_url to allow the TinyMCE editor to see a list of previously uploaded files in EE. However, I’ve been having significant difficulties in making this method work - there’s little detail in how things fit together (the calls to nested queries, the set up of the new templates) and the templates I’ve created don’t render the PHP within them to produce the list of images as a javascript array. Has anybody made this work correctly? I’m working locally on a WAMP server on my desktop machine at the moment - not sure if that makes any difference?
I’ve also seen the article http://www.wil-linssen.com/tinymce-wysiwyg-editor-with-tinybrowser-file-browser-in-expression-engine/ about using Tiny Browser, and am tempted to try that out, in preference to the above solution: would people recommend that as a solution?
Anthony.
Electric Putty's avatar
Electric Putty
17 years ago
Electric Putty's avatar Electric Putty
Hi Anthony,
As an alternative to TinyMCE you could give the epEditor a go.
The EE Extension for epEditor comes ready integrated into EE’s proprietary file system. This means once you’ve installed the Extension you can navigate your upload directories and insert images without any additional templates or JavaScript.
More information is available here.
Best wishes,
Malcolm
werxstudio's avatar
werxstudio
16 years ago
werxstudio's avatar werxstudio
For some reason I cannot get epEditor to insert an image.
I can view the upload directories, select the image but nothing happens when I hit insert.
Running the latest version both of EE 1.6.8 and epEditor 1.0.5
Any suggestions?
Electric Putty
16 years ago
@rcamu: I think you are having the same issue as @Dave_H
Check this post: http://ellislab.com/forums/viewthread/98244/P72/#603270
Hopefully this will solve your problems.
werxstudio's avatar
werxstudio
16 years ago
Yup…that did it. Is there any way to have it check the domain name and allow the use of the insert image from both www.domain.com and domain.com?
This would help primarily with the client once they start editing the site.
BTW, great work!
Electric Putty
16 years ago
@rcamu: This will be part of the next release which will hopefully be available by the end of the month.
