Active class for <li> using weblog categories
Clearpeak's avatar
Clearpeak
17 years ago
Clearpeak's avatar Clearpeak
I’m using the weblog categories tag style=nested to generate a multi-level list and I need to apply a style to a <li> to keep it open to the page being viewed. I see the hook, parament id= and class= to add a style to the <ul> but is there anyway to add a style to a <li>? Or a plugin?
Moved to Plugins by Moderator
Greg Aker's avatar
Greg Aker
17 years ago
Greg Aker's avatar Greg Aker
fodney:
Take a look at this thread or this one and let us know if that helps.
-greg
Clearpeak's avatar
Clearpeak
17 years ago
Thanks Greg. Yeah I had seen those. Trying to do it for a nested list. I’ll see if I can find a plugin.
Sue Crocker's avatar
17 years ago
fodney, are the links that Greg posted enough to answer your technical questions? I can move the post to the plugins forum if you’d like.
Clearpeak's avatar
Clearpeak
17 years ago
That’s fine. Thanks.
