Code that is allways run
EpicSoft's avatar
EpicSoft
17 years ago
EpicSoft's avatar EpicSoft
What i am looking to do is run some code every time a page of the /system/ is loaded. If i could run it as soon as the user signs on or after every time the “Publish” button was used that would be ideal.
Basically set up like a cronjob but it wont run unless you sign on, post, or update an entry.
Anyone have an idea as to where i should put this code beside throwing an include(“foo.php” inside of system/index.php
Greg Salt's avatar
Greg Salt
17 years ago
Greg Salt's avatar Greg Salt
Have a look at any of the session_start,session_end, show_full_control_panel_end or show_full_control_panel_end extension hooks.
Cheers
Dry
EpicSoft's avatar
EpicSoft
17 years ago
Thanks i got it to work just too well. So well that once i enabled the extension my code is the ONLY thing that ran. After some digging in jquery i got a working example and got it working. Thanks for pointing me in the right direction.
Here is my solution just in case any oen else is looking for this.
in side your function activate_extension()
$DB->query($DB->insert_string('exp_extensions',
                                  array(
                                        'extension_id' => '',
                                        'class'        => "extension_name",
                                        'method'       => "shoulddothiswhenit_ends",
                                        'hook'         => "show_full_control_panel_end",
                                        'settings'     => "",
                                        'priority'     => 10,
                                        'version'      => $this->version,
                                        'enabled'      => "y"
In side your class
function shoulddothiswhenit_ends($html)
        return "foo bar ".$html;
