field broken? (Freeform)
Sr. Coffee's avatar
Sr. Coffee
17 years ago
Sr. Coffee's avatar Sr. Coffee
I am having a problem with a field that was created for Freeform. I have several forms that write data to a field named ‘release’. While the html pages correctly display the data, all my csv templates stopped working until I deleted that field from the queries.
Also, I found that if I went to Modules › Freeform › Manage Fields › Edit Field for ‘release’ and hit the update button, it would throw an error:
Error Number: 1064
Description: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘release release varchar(10) NOT NULL’ at line 1
Query: ALTER TABLE exp_freeform_entries CHANGE release release varchar(10) NOT NULL
Using v 1.6.4 (Yes, I know.)
Mod Edit: Moved to the Modules: Discussion and Questions forum.
Sr. Coffee's avatar
Sr. Coffee
17 years ago
Please?
smartpill's avatar
smartpill
17 years ago
smartpill's avatar smartpill
Try Solspace’s forum for Freeform.
