Extension: jQuery Quick Save
MeanStudios's avatar
MeanStudios
17 years ago
MeanStudios's avatar MeanStudios
Greetings,
I have updated this script to 2.0 which added an Auto-Save feature as suggested bellow. I’ve also included the hotkeys js file in with the extension so you don’t have to download it yourself. I’ve also moved the hosting of this script to GitHub to try and follow the example of other developers of EE addons. You can find the files and instructions here: http://github.com/MeanStudios/ms.quick_save.ee_addon/.
If you are using an older version, I highly recommend you disable it in the extensions manager before uploading this new one.
Special thanks to @brandonkelly for helping get this on to GitHub and also for letting me use his extension template 😊.
MeanStudios
17 years ago
I updated the setup instructions to be more clear.
eyevariety's avatar
eyevariety
17 years ago
eyevariety's avatar eyevariety
Very cool. I always hit ctrl+s too.
Would love to see an “auto-save” built into this, where it would auto save draft changes after a specified time.
MeanStudios
17 years ago
Great Idea! I will implement that in next version 😊.
MeanStudios
17 years ago
I’ve updated the original post with version 2.0. Enjoy!
wecreateyou's avatar
wecreateyou
16 years ago
wecreateyou's avatar wecreateyou
This is pretty cool. I’m a big fan of Hot Keys. They’ve been a unconscious part of my workflow in nearly every software app I use. Thanks for this.
