Countdown Plugin Zeros Out
Perak's avatar
Perak
21 years ago
Perak's avatar Perak
Little problem with the Countdown plugin: it always says there are 0 days and 0 hours left until the event. I dropped the plugin into the plugins folder, added the code properly. I haven’t found a mention of this happening to anyone else.
If it means anything, the code is on an embedded template.
Perak's avatar
Perak
21 years ago
Curiouser and curiouser, as they say. I changed the year to 2005 and some arbitrary date, and it seemed to work. So I set date at 25, month at 12 and year at 2004 to see if perhaps we were a month off (for whatever reason). The result was 17 days and 9 hours to Thanksgiving. Not right at all, days or hours.
Posting times from my server are correct.
Janine's avatar
Janine
21 years ago
Janine's avatar Janine
yes I am having the same problems with it
Perak's avatar
Perak
21 years ago
Glad to hear it wasn’t just me. 😊
rish's avatar
rish
20 years ago
rish's avatar rish
Reports zero for me as well :(
{exp:countdown day="20" month="2" year="2006" hours="4" event="Start Gun"}
There are 0 days and 0 hours until Start Gun
Sue Crocker's avatar
20 years ago
Rish, if the countdown date has expired (yours has) you’ll see 0 days and 0 hours display.
Mine works just fine on a date that is in the future.
Days Until St. Patrick’s Day There are 18 days and 18 hours until St. Patrick’s Day
rish's avatar
rish
20 years ago
rish's avatar rish
Very good! One month ahead of myself 😊
All good, thanks.
smartpill's avatar
smartpill
19 years ago
smartpill's avatar smartpill
I’m using the Countdown plugin (1.2) with EE 1.5.2 and the hours parameter doesn’t seem to work. I’m trying to set it to 5pm, which I have as
hours="17"
but it is being ignored. Otherwise, the day date and year are working fine. Anybody have any suggestions?
jochta's avatar
jochta
17 years ago
jochta's avatar jochta
hours="17"
Old topic but just installed the plugin and spotted the same problem in v1.2. Two things, the parameter should be hour=”17” and not hours and there is a bug in the code.
Line 31 in pi.countdown.php has an error, it should read…
//make unix timestamp for given date
  $countdowndate = mktime($hour, 0, 0, $month, $day, $year);
It was using the $hour parameter in the seconds position of mktime.
John
