Amazon ECS (AWS4) Plugin
LeuMund's avatar
LeuMund
21 years ago
LeuMund's avatar LeuMund
Just made a new Amazon Plugin wich uses Amazon ECS and only works with PHP5 and simple_xml.
More Informations
Please give me some Feedback about this if you can use it 😊
PXLated's avatar
PXLated
21 years ago
PXLated's avatar PXLated
LeuMund… Did a lot of reading in the Amazon Developers area this evening as I needed to modify Lynda’s pluging to include more data. That plugin uses the v3 APIs/SDK whereas their new version is 4. Alot of us don’t run our own servers and most hosts I know of haven’t switched over to PHP5 yet. How hard would it be to get your plugin working with PHP4? Would love to tie into the new Amazon stuff but it’s a now show for me with the v5 requirement :-(
PXLated's avatar
PXLated
21 years ago
Just got some responses back from hosting services and none are upgrading anytime soon. They estimated next year sometime. They tend to need/value stability first, new features second, which I can understand.
LeuMund's avatar
LeuMund
21 years ago
my hosting company in switzerland www.hostpoint.ch has a great functionality. they installed php5 together with php4 and i can decide for each directory if i want to run php5 or php4. it’s perfect for testing and it was also to move the ecs directly to php5 with simple_xml.
i will see, if it will be possible to use soap for the same plugin to have it working for php4. what i’m wondering is, everyone asked lynda for php5 compatibility of amazon api plugin…
PXLated's avatar
PXLated
21 years ago
LeuMund… >> everyone asked lynda for php5 compatibility of amazon api plugin << Hmmm…didn’t notice that…lots of requests for caching I recall 😊 I haven’t found any of the hosts I’ve used/use with PHP5 and I know pMachineHosting probably won’t have it until sometime next year. So, I’m kind of curious as to how many actually have it. Could just be a vocal minority 😊
Really like the idea of using the new Amazon v4 Services though. ASIN lookup is the most common for my needs and if there was a way to handle things when it returns an array would be peachy. Lynda’s version is limited to single item/phrase returns.
I think if more people knew just what you can do with the Web Services, more would use it. Especially affiliates. It’s far more useful/robust then the simple affiliate links that are so typical. As far as Soap…A client of mine deals with Amazon a lot and they seem to push Soap for their suppliers and drop-shippers even though they do offer straight email communication for the very small suppliers like in their gourmet foods section. Sure wish I knew how to really program 😊
LeuMund's avatar
LeuMund
21 years ago
I’m just testing a extended Version now wich supports ASIN Lookup and ASIN Similarity Search. I will publish it soon, but you can have a look at it and how it works at <a href=”http://www.leumund.ch/x/v3/shop”>leumund.ch</A>
PXLated's avatar
PXLated
21 years ago
Cool
LeuMund's avatar
LeuMund
21 years ago
version 1.1 is available for download now!!!
<a href=”http://www.leumund.ch/pi.ecs.tar”>Download Version 1.1</a>
New Variables:
{review}
{review_content}
{review_date}
Gives back first review to each product. First one is summary.
New function:
action=”search” Existing
action=”lookup” action=”similar” (Needs ASIN between {define_keywords))
Check back soon for more functions soon!
Halogen's avatar
Halogen
21 years ago
Halogen's avatar Halogen
Can you give some example usage?
Hop Studios's avatar
Hop Studios
16 years ago
Hop Studios's avatar Hop Studios
Any chance you’ll be updating this plug-in?
