1054 Error
Clearpeak's avatar
Clearpeak
17 years ago
Clearpeak's avatar Clearpeak
I just created a new weblog and then I created a playa field in another weblog and selected the new weblog as the related and now when I try to go to the weblog entry with the playa field I get a 1054 error.
My Playa fields were working fine a minute ago before I created this new weblog. Here’s the error:
MySQL ERROR:
Error Number: 1054
Description: Unknown column ‘Writer’ in ‘where clause’
Query: SELECT rel_id, rel_child_id FROM exp_relationships WHERE rel_id IN (Writer)
Any ideas what I did wrong?
Clearpeak's avatar
Clearpeak
17 years ago
Thanks. I figured it out. I had changed the field type to playa and the old field type had text in it and that caused the error.
