Twitter Timeline shows nothing
pixelmatrix's avatar
pixelmatrix
17 years ago
pixelmatrix's avatar pixelmatrix
I’m using the latest Twitter Timeline plugin (1.2) and the latest EE version (1.6.6), but for some reason I cannot get the Twitter Timeline plugin to show anything at all.
If I can get the page to load that contains the Twitter box, it shows nothing in the area between the {exp:twitter_timeline} tags.
I’ve searched the forum a lot, and had no luck finding any information about this issue.
Here’s my code:
{exp:twitter_timeline type="user" limit="1" user="pixelmatrix" password="***********"}
                        <div id="twitter-out">
                            <div id="twitter-in">
                                <div id="twitter-innermost">
                                    <div class="text">
                                        {text}
                                    </div><!-- .text -->
                                    <div id="twitter-name">
                                        <a href="http://{url}" title="{name} on Twitter">{profile_image_url}<a>_                                            <a href="{url}" title="{name} on Twitter">{screen_name}</a>
                                    </div><!-- #twitter-name -->
                                </div><!-- #twitter-innermost -->
                            </div><!-- #twitter-in -->
                        </div><!-- #twitter-out -->
                        {/exp:twitter_timeline}
Can anyone help?
otto's avatar
otto
17 years ago
otto's avatar otto
Seems I’m getting errors on mine as well.
Warning: Invalid argument supplied for foreach() in *****/plugins/pi.twitter_timeline.php on line 302
That warning comes up twice.. and nothing showing.
Very strange. There aren’t many variables to put in, but somethings not working right? EE 1.6.6
otto
otto's avatar
otto
17 years ago
otto's avatar otto
Just an addition… Stuff shows up if the user is “public”… but when I try and use my account name and password, that’s when I get the errors. Very strange. Something not going through? Another setting we’re missing?
Blue Flavor's avatar
Blue Flavor
17 years ago
Blue Flavor's avatar Blue Flavor
I’m getting this to, has anyone been able to solve this problem?
Derek Jones's avatar
Derek Jones
17 years ago
Have you tried using your email address instead of your Twitter username?
user=”[email protected]” - Email address of Twitter user. Required for “user” or “friends” timelines
otto's avatar
otto
17 years ago
otto's avatar otto
yup. tried one… then the other… etc. Nada. Same error message.
Blue Flavor
17 years ago
Yes actually. But I used the Twit-ee module instead and that’s working now. This one looks really great. I’m going to try and find a better description of the problem later, but right now I don’t want to waste your time.
Derek Jones
17 years ago
Brief update, I setup our Twitter Timeline plugin to email me some debugging info if this failure occurred, and as I thought might be the case, Twitter isn’t returning any of its standard errors, but a rather unpredictable 500 internal server error. It’s only occurred once since the 18th when I set this up, so I’m going to wait for some more sample data if the error’s triggered again before trying to accommodate this in the plugin code.
Derek Jones
17 years ago
False alarm, it’s trapping things fine even with the new “we’re experiencing problems” HTML page that is delivered instead of an appropriate XML response. Anyone experiencing problems, please double check that you are running the latest version of the plugin.
