Plugin: Convert users after time period
Chris Newton's avatar
Chris Newton
17 years ago
Chris Newton's avatar Chris Newton
I created a plugin that will convert a user from one group to another, if that user is older than a specified amount of time. This looks at the user’s creation date, and converts them X seconds from the time they were created.
Caveats: 1. This won’t allow you to convert to or from super admin status. 2. This doesn’t account for server time offset, so 86400 seconds might be more or less than one day, by a few hours (or whatever your server offset is)
Example usage: {exp:convert_users_after_time_period convert_from="6" convert_to="3" seconds="86400"}
Basically, I wanted to expire users after 24 hours. This plugin can be used for that purpose, or to create a testing or waiting period for a user. Use this by either adding the plugin to a page and hitting that page with CRON (more often than your seconds to conversion), or put it on a highly trafficked page so it gets hit pretty often.
