Plugin: WI Friendlee Date - Convert supplied date parts to a friendly date output.
Chad Crowell's avatar
Chad Crowell
17 years ago
Chad Crowell's avatar Chad Crowell
As if there weren’t enough date based plugins… this is something I needed for a client. Could be useful in the right situations.
{exp:wi_friendlee_date m="month" d="date" y="year" h="hours" mn="minutes" s="seconds" display="php date codes"}
Place this tag in your code and replace month date year hours minutes seconds parameters in the code with any information to have the plugin return the date formatted nicely.
Only m, d and y are required. If no h, mn or s parameters are supplied, the plugin will not add hours, minutes or seconds into the generated date/time.
You can control the display that is output by entering typical PHP date formatting codes into the display parameter. See http://us2.php.net/date for all available options.
The default display, if you don’t supply a display parameter is MM/DD/YYYY.
Examples:
{exp:wi_friendlee_date m="6" d="24" y="1995"}
Output: 06/24/1995
{exp:wi_friendlee_date m="6" d="24" y="1995" h="9" mn="55" s="00"}
Output: 06/24/1995 09:55:00
{exp:wi_friendlee_date m="6" d="24" y="1995" display="D, F jS, Y"}
Output: Sat, June 24th, 1995
{exp:wi_friendlee_date m="6" d="24" y="1995" h="9" mn="55" s="00" display="D, F jS, Y, g:i:s"}
Output: Sat, June 24th, 1995, 9:55:00
{exp:wi_friendlee_date m="{segment_4}" d="{segment_5}" y="{segment_6}" display="D, F jS, Y"}
URL: www.mydomain.com/template_group/template/url_title/6/24/1995/ Output: Sat, June 24th, 1995
Sue Crocker's avatar
17 years ago
Thanks for sharing, Chad. I can find a use for this.
Laisvunas's avatar
Laisvunas
17 years ago
Laisvunas's avatar Laisvunas
Hi Chad,
There are at least two plugins having very similar functionality: Nice Date and Formatted Date.
Chad Crowell
17 years ago
Yes I know, but since I had written it, I figured some others may like it.
Leevi Graham's avatar
Leevi Graham
16 years ago
Hey Chad,
I only wanted the month and year for my archive heading so I slightly modded your plugin. Basically I added some default options to the dat vars so mktime doesn’t break.
$m            = $TMPL->fetch_param('m') ? $TMPL->fetch_param('m') : 1;
$d            = $TMPL->fetch_param('d') ? $TMPL->fetch_param('d') : 1;
$y            = $TMPL->fetch_param('y') ? $TMPL->fetch_param('y') : 0;
$h            = $TMPL->fetch_param('h') ? $TMPL->fetch_param('h') : 0;
$mn            = $TMPL->fetch_param('mn') ? $TMPL->fetch_param('mn') : 0;
$s            = $TMPL->fetch_param('s') ? $TMPL->fetch_param('s') : 0;
$display    = $TMPL->fetch_param('display');
Then I scrapped the warning. Now I can do cool stuff like:
There were no posts published in {exp:wi_friendlee_date m="{segment_4}" y="{segment_3}" display="F Y"}
Chad Crowell
16 years ago
Sweet! I like when people smarter than me make my stuff even better. Feel free to branch the Git repo if you want.
kpow's avatar
kpow
16 years ago
kpow's avatar kpow
Any idea if this plugin could be used in conjunction with the simple math plugin? (http://ellislab.com/forums/viewthread/110055/P36/#631282) I was trying to get a date calculated such as: I have a field (days) that has 10 (or 20 or ..) and I have a field for date such as 12/12/2009. I wanted to have the {date}+(days) output the result in a date format: 12/22/2009. is there a easy way to do such?
