$DSP issue
EpicSoft's avatar
EpicSoft
17 years ago
EpicSoft's avatar EpicSoft
$DSP->foobar works fine in my mcp..php but in my mod..*php i get
Fatal error: Call to a member function input_select_header() on a non-object in C:\live_websites\foobar…
My globals match on both functions and classes so i don’t under stand why it would fail in once place and not the other. Any ideas?
Derek Jones's avatar
Derek Jones
17 years ago
The Display class is only loaded in the control panel.
EpicSoft's avatar
EpicSoft
17 years ago
As soon as i got out of the door at work I asked my self if that was the case. Thank you for confirming it.
Derek Jones
17 years ago
No problem. You could of course instantiate the class and utilize it, but just keep in mind that that’s not intended, so it would only be useful to you for methods that return values. And typically module front end tags should not be outputting their own markup, but parsing variables within markup that’s specified in the template, so that the user retains full control over all output.
