LG Data Matrix 1.0.0 Works on One MSM Site, Doesn't Work on Another
kirkaracha's avatar
kirkaracha
17 years ago
kirkaracha's avatar kirkaracha
I’m using LG Data Matrix 1.0.0 on one of my MSM sites, but it’s not working when I use it on a different site, it just displays the Data Matrix code from the template without rendering it. The main difference is that the site where it’s not working is pulling entries from a weblog on a another MSM site.
  1. I uploaded a freshly-downloaded copy of version 1.0.0.
  2. The extension is enabled in Admin > Utilities > Extensions Manager
  3. The extension is enabled for each site in Admin > Utilities > Extensions Manager > LG Data Matrix 1.0.0
  4. The paths to both required JavaScripts are correct (the extension works on the Publish/Edit screens, but not in the rendered template).
  5. I updated EE and MSM to the latest builds.
This code works on one of my sites):
{if news_releases_related_links}
{news_releases_related_links disable="headers"}
<h3>Related Links</h3>
<dl>{rows}
    <dt><a href="http://{related_url}">{related_title}</a></dt>
    {if related_note}<dd>{related_note}</dd>{/if}
{/rows}</dl>
{/news_releases_related_links}
This code doesn’t work on one of my other sites):
{if internal_comm_related_links}
{internal_comm_related_links disable="headers"}
<dl>{rows}
{/rows}</dl>
{/internal_comm_related_links}
  1. internal_comm_related_links is the correct name of the custom field.
  2. related_url, related_tracking, related_title, and related_note are the correct names from the custom field settings.
  3. custom_fields is not disabled in any of the exp:weblog:entries tags.
  4. The weblog entry has content in the Data Matrix custom field
It also doesn’t work in a reduction test with a simpler template):
{exp:weblog:entries site="ucsf_today" weblog="internal_comm_stories" require_entry="yes" limit="1"  disable="member_data|pagination|trackbacks"}
{title}
<dl>{rows}
{/rows}</dl>
{/exp:weblog:entries}
A further reduction without any conditionals also doesn’t work):
{title}
<h2>Related Links</h2>
<dl>{rows}
{/rows}</dl>
ExpressionEngine 1.6.6 Build: 20081212 PHP/5.1.6 MySQL 5.0.45 Apache/2.2.3
