I have just installed EE and have a blank control panel. The main index of the site shows up just fine, but the control panel is not working at all.
I installed it once already, and BOTH the site and the control panel were blank. After going through all the suggestions I could find, I finally deleted everything and started over. This time only half of the problem is fixed.
I have forced error reporting, and I get the following error:
Warning: main(): Unable to access ../system/core/core.system.php in /var/www/vhosts/heatherkate.com/httpdocs/system/index.php on line 8
Warning: main(../system/core/core.system.php): failed to open stream: No such file or directory in /var/www/vhosts/heatherkate.com/httpdocs/system/index.php on line 8
Fatal error: main(): Failed opening required '../system/core/core.system.php' (include_path='.:') in /var/www/vhosts/heatherkate.com/httpdocs/system/index.php on line 8(I have replaced the new system name with “system” for this post.)
I am all out of brain cells now, and still don’t have a working control panel, and a funky website for the moment.
Thank you for your help!
Heather
