Site Not Showing Up Correctly
May 28, 2010 4:36pm
  • #1 / May 28, 2010 4:36pm
    grilldan
    I am working on a clients website. I have an exact copy of the files/db.
    I edited the config file to use the local database, however, when I browse to the index page, all I see is:
    - A few links (home, about, archives, contact) in a list
    - About “Quote Meon an estimate…” Lorem Ipsum
    - A Calendar
    - A Search bar
    - Categories (blank)
    - Monthly Archives
    - Most recent entries (blank)
    - Syndicate (atom, rss 2.0)
    - Site Statistics
    I am assuming this is a “default” page of some sort.
    How can I change this to show the clients website?
  • #2 / May 28, 2010 4:39pm
    Welcome to the ExpressionEngine forums, grilldan.
    What you’re seeing is the site template for EE1.6.x. You would have needed to create a new template group with different things in it, or have edited the site template group.
    Did you do either of these?
  • #3 / May 28, 2010 4:42pm
    grilldan
    The only file I edited was the config file, to use the local database. Other than that, it is an exact copy of the files from their server.
  • #4 / May 28, 2010 4:46pm
    Did you also copy over the your local install with their database?
  • #5 / May 28, 2010 10:21pm
    grilldan
    Here is what I did:
    1) Copied files from their server to my server
    2) Did a dump on their database, imported it into mine
    3) Changed config to use local db
    4) Opened a browser and navigated to the index.php page
    Which brings us up to now.
  • #6 / May 29, 2010 1:25pm
    Can you give us a link to the site? Be sure to take a look at this article, too.
  • #7 / May 29, 2010 4:11pm
    grilldan
    I can’t give a link to the site, because the error is on my local testing server. I’ve tried a new copy of the files/db and the same thing happens… Could it be a permissions error?
    *edit* Doesn’t seem to be a permissions error : /
  • #8 / May 30, 2010 6:32am
    Can you post a screen shot, at least? It’s a bit difficult to troubleshoot issues we can’t see for ourselves.
  • #9 / May 31, 2010 1:26am
    grilldan
    Understandable.
  • #10 / May 31, 2010 6:15am
    Double check your .css file; try to bring it up in the browser directly.
  • #11 / Jun 01, 2010 4:31pm
    grilldan
    That could be what the issue is. It is trying to @import directly from their website, instead of locally. How could I change this?
    On their website, it looks like:
    <link href="/css/default.css" type="text/css" rel="stylesheet" />
    On my local server, it looks like:
    <link rel='stylesheet' type='text/css' media='all' href='http://theirwebsite.com/index.php?css=site/site_css' />
    <style type='text/css' media='screen'>@import "http://theirwebsite.com/index.php?css=site/site_css";</style>
    It almost looks like their website is using a different theme than the local version I have, but I have exact copies of the files/db, so it must be something on my end.
  • #12 / Jun 01, 2010 4:52pm
    Does the CSS load when you bring it up directly in the browser? That’s the real question.
  • #13 / Jun 01, 2010 5:01pm
    grilldan
    No. Nothing loads, except that default page.
    I can navigate to the admin login page (also no css), but once I enter my login info, it goes to a completely blank page.
  • #14 / Jun 01, 2010 6:01pm
    Does the same thing happen for the control panel, or does it only affect the front page?
  • #15 / Jun 01, 2010 6:09pm
    grilldan
    It happens on every page. I can’t get to the control panel, I can get to the login page (no styles), but once I login, I am taken to a blank page.
