I am developing a site locally, using MAMP on a Mac with EE 1.6.7. The problem occurs both when using Safari or Firefox.
I have imported about a 100 records via CSVGrab (this may or may not be to do with my problem).
Whenever I turn on any extension, and then try to switch to the Edit Page, or try to edit a specific weblog entry, all I get is a blank page.
I have been working with most extensions switched off, but I am getting to the point where I need to investigate this.
The only extensions I have currently on without a problem are:
Admin Section With Tabs! (v.1.0.1)
Clone Entries (v.1.1)
As soon as I turn on any other extension (e.g. Edit Menu, EEvent Helper), the problem occurs.
So I have done some preliminary investigations:
When I use the SQL Manager to browse tables, all the tables are OK, except the same blank page occurs when trying to browse:
exp_weblog_data Browse 124 220.6 KB
So my guess is something happened on importing those weblog entries via CSVGrab that interfered with the storage of that data. It could be that this occurs when some javascript functions are involved ??
I had a similar problem before when I was experimenting months ago on a completely different set of data and CSVGrab.
Can you recommend some steps to isolate the error ? Anything else I can do ?
Thanks for any help.
Michael
PS: I posted the same problem yesterday under extensions, but did not get any responses, as I’m presenting it rather vaguely and without much concrete evidence, I guess.
