Not able to display images
October 06, 2009 5:50pm
Subscribe [7]
  • #1 / Oct 06, 2009 5:50pm
    shinokada
    I am using XAMPP and created a directroy htdocs/codeigniter_shopping.
    Inside that directroy I have an image directory same level as system directory.
    htdocs/codeigniter_shopping/images
    htdocs/codeigniter_shopping/system
    I have .htaccess as follows.
    RewriteEngine on
    RewriteCond $1 !^(index\.php|images|captcha|css|js|robots\.txt)
    RewriteRule ^(.*)$ index.php/$1 [L]
    I have stored paths to images in database.
    /images/dummy-thumb.jpg
    However it does not display any image.
    I am able to see an image in the following URL.
    http://127.0.0.1/codeigniter_shopping/images/dummy-thumb.jpg
    So I tried ../images/dummy-thumb.jpg, images/dummy-thumb.jpg etc but none of them worked.
    I am hoping if someone can give me ideas how to store the path to image.
    Or do I need to change any .htaccess or not.
    Thanks in advance.
  • #2 / Oct 06, 2009 6:59pm
    jedd
    Why not?
    As in - when you look at your page source in your browser, can you determine if the pathing is wrong, or if the tag is wrong, or if .. (etc - you get the idea).
    You could use something like this:
    $img_array = array ("src"=> "/codeigniter_shopping/images/dummy-thumb.jpg",  "width" => "180px", "border"=>"0", "alt"=>"some text");
    echo anchor (img($img_array ));
  • #3 / Oct 06, 2009 8:09pm
    Colin Williams
    How is it that 60% - 70% of “CodeIgniter problems” people experience is something as simple as resolving paths. Take a step back people. Learn the fundamentals.
  • #4 / Oct 06, 2009 8:25pm
    Zack Kitzmiller
    *clap* *clap*
    Show us the code the CI is outputting to the browser. Then maybe we can help you.
  • #5 / Oct 07, 2009 2:58am
    shinokada
    When I see http://127.0.0.1/codeigniter_shopping/, it shows images by using the image path images/dummy-thumb.jpg.
    However when I visit http://127.0.0.1/codeigniter_shopping/welcome/index or
    http://127.0.0.1/codeigniter_shopping/welcome/product/1
    no images will shown.
    The links are working.
    It seems that I have to add http://127.0.0.1/codeigniter_shopping/images/dummy-thumb.jpg to show images.
    <div class='productlisting'>images/dummy-thumb.jpg
    <h4>Dress 1</h4>
    <p><a href="http://127.0.0.1/codeigniter_shopping/welcome/product/10" title="see details">see details</a><br><br />
    <a href="http://127.0.0.1/codeigniter_shopping/welcome/cart/10" title="add to cart">add to cart</a><br />
    </div>
  • #6 / Oct 07, 2009 3:33am
    Colin Williams
  • #7 / Oct 07, 2009 4:17am
    InsiteFX
    site_url()
    Returns your site URL, as specified in your config file. The index.php file
    (or whatever you have set as your site index_page in your config file)
    will be added to the URL, as will any URI segments you pass to the function.
    You are encouraged to use this function any time you need to generate a local URL
    so that your pages become more portable in the event your URL changes.
    Segments can be optionally passed to the function as a string or an array.
    READ CodeIgniter user guide.
    Enjoy
    InsiteFX
  • #8 / Oct 07, 2009 4:29am
    shinokada
    Thanks to InsiteFX for a constructive reply.
    I thought the same thing and I experimented to find out all the path and the below is the results.
    The siteurl() gives with index.php at the end, so I will test it with baseurl.
    Or I will define the path to images folder in config file to use it.
    Interesting thing is that CI shows BASEPATH as C:\xampp\htdocs\ci_day6/system/ in XAMPP.
    This means BASEPATH in windows will not work. I suggest to check index.php.
    Basepath: C:\xampp\htdocs\ci_day6/system/
    Apppath: application/
    Ext: .php
    Fcpath: C:\xampp\htdocs\ci_day6\index.php
    Self: index.php
    baseurl: <a href="http://127.0.0.1/ci_day6/">http://127.0.0.1/ci_day6/</a>
    site_url(): <a href="http://127.0.0.1/ci_day6/index.php">http://127.0.0.1/ci_day6/index.php</a>
    current_url(): <a href="http://127.0.0.1/ci_day6/index.php/welcome">http://127.0.0.1/ci_day6/index.php/welcome</a>
    uri_string(): /welcome
    index_page(): index.php
    realpath(__FILE__): C:\xampp\htdocs\ci_day6\application\views\welcome_message.php
    realpath(dirname(__FILE__)): C:\xampp\htdocs\ci_day6\application\views
    realpath(dirname(__FILE__)): C:\xampp\htdocs\ci_day6\application\views/
    str_replace: C:/xampp/htdocs/ci_day6/application/views
    getcwd(), current working directory: C:\xampp\htdocs\ci_day6
  • #9 / Oct 07, 2009 9:48am
    InsiteFX
    You can fix that problem by using this code, I did not write this several other users on the forum here wrote it.
    Place in application/config/constants.php
    | Docment root folders
    | These constants use existing location information to work out web root, etc.
    // Base URL (keeps this crazy sh*t out of the config.php
    if (isset($_SERVER['HTTP_HOST']))
        $base_url  = isset($_SERVER['HTTPS']) && strtolower($_SERVER['HTTPS']) == 'on' ? 'https' : 'http';
        $base_url .= '://'. $_SERVER['HTTP_HOST'];
        $base_url .= str_replace(basename($_SERVER['SCRIPT_NAME']), '', $_SERVER['SCRIPT_NAME']);
        // Base URI (It's different to base URL)
        $base_uri = parse_url($base_url, PHP_URL_PATH);
        if (substr($base_uri, 0, 1) != '/')
            $base_uri = '/'.$base_uri;
        if (substr($base_uri, -1, 1) != '/')
            $base_uri .= '/';
    else
        $base_url = 'http://localhost/';
        $base_uri = '/';
    // Define these values to be used later on
    define('BASE_URL', $base_url);
    define('BASE_URI', $base_uri);
    define('APPPATH_URI', BASE_URI.APPPATH);
    define('ASSETS_URL', $base_url."assets/");
    define('CSS_URL', ASSETS_URL."css/");
    define('IMAGE_URL', ASSETS_URL."images/");
    define('JS_URL', ASSETS_URL."js/");
    define('UPLOAD_URL', ASSETS_URL."upload/");
    define('DOWNLOAD_URL', ASSETS_URL."download/");
    // We dont need these variables any more
    unset($base_uri, $base_url);
    I have modified it to use more constans.
    Enjoy
    InsiteFX
  • #10 / Oct 15, 2009 10:02am
    shinokada
    I added the following in the head.
    <base href="<?=base_url();?>">
    Then all the links work.
  • #11 / Oct 15, 2009 10:51am
    renownedmedia
    If you ever have problems like this again, right click on your broken image and click view image. This will give you the URL your browser is trying to find the image at. That should be the first step with this sort of problem solving.
    Ideally, install firebug and you see things like this lit up in red!
  • #12 / Nov 01, 2009 9:46pm
    doubleplusgood
    XAMPP has tripped me up a few times with paths. I develop at home on my Mac and things like using <?=site_url(’‘)?> work perfectly in links for images/styles and so on, but transfer to a Windows computer and XAMPP (when I’m doing my day job) and the same code no longer works. Even when you view source, it includes the <?=site_url(’‘)?> in the links. Very odd - as everything else php related works fine; controllers, views etc.
