Carabiner 1.0: Asset Management Library
January 28, 2009 9:23pm
Subscribe [19]
  • #1 / Jan 28, 2009 9:23pm
    tonydewan
    NOTE: Carabiner has been updated to version 1.42.  See the new thread for more info and to download.
    Cara-wha?
    Carabiner is a library for managing JavaScript and CSS assets.  It’s different from others that currently exist (for CodeIgniter, anyway) in that it acts differently depending on whether it is in a production or development environment.  In a production environment, it will combine, minify, and cache assets. (As files are changed, new cache files will be generated.) In a development environment, it will simply include references to the original assets.
    Requirements
    Carabiner requires the JSMin and CSSMin libraries that I previously ported.  They’re both included in this release.  You don’t need to load them, unless you’ll be using them elsewhere.  Carabiner will load them automatically as needed. (Note: the only reason they’re included as separate libraries is that it allows you to use them independently of Carabiner.  If desired, you could probably include them in the carabiner.php file itself.  You’d have to edit the Carabiner functions, but it could work.)
    GZIP, Packer, etc.
    Carabiner does not implement GZIP encoding, because I think that the web server should handle that.  I think GZIPing is important, I just prefer not to do it PHP. If you need GZIP in an Asset Library, AssetLibPro does it.  I’ve also chosen not to implement any kind of JavaScript obfuscation (like packer), primarily because of the client-side decompression overhead. More about this idea from John Resig. However, that’s not to say you can’t do it.  You can easily provide a production version of a script that is packed.  However, note that combining a packed script with minified scripts could cause problems.  In that case, you can flag it to be not combined. (See usage below) Also, that’s not to say that I won’t port a PHP Version and include it eventually.
    Inspiration/License
    Carabiner is inspired by Minify, PHP Combine by Niels Leenheer and AssetLibPro by Vincent Esche, among other things. Carabiner is released under a BSD License.
    Usage
    Load the library as normal:
    $this->load->library('carabiner');
    Configure it like so:
    $carabiner_config = array(
        'script_dir' => 'assets/scripts/',
        'style_dir'  => 'assets/styles/',
        'cache_dir'  => 'assets/cache/',
        'base_uri'   => $base,
        'combine'    => TRUE,
        'dev'        => FALSE
    $this->carabiner->config($carabiner_config);
    There are 8 relevant configuration options.  The first 4 are required for Carabiner to function, the last 4 are not.
    script_dir
    STRING Path to the script directory.  Relative to the CI front controller (index.php)
    style_dir
    STRING Path to the style directory.  Relative to the CI front controller (index.php)
    cache_dir
    STRING Path to the cache directory.  Must be writable. Relative to the CI front controller (index.php)
    base_uri
    STRING Base uri of the site, like ‘http://www.example.com/’
    dev
    BOOLEAN Flags whether your in a development environment or not.  See above for what this means. Defaults to FALSE.
    combine
    BOOLEAN Flags whether to combine files.  Defaults to TRUE.
    minify_js
    BOOLEAN Flags whether to minify javascript. Defaults to TRUE.
    minify_css
    BOOLEAN Flags whether to minify CSS. Defaults to TRUE.
    Add assets like so:
    $this->carabiner->js('scripts.js');
    $this->carabiner->css('reset.css');
    $this->carabiner->css('admin/styles.css');
    To set a (prebuilt) production version of an asset:
    // pass a second string to the method with a path to the production version
    $this->carabiner->css('wymeditor/wymeditor.js', 'wymeditor/wymeditor.pack.js' );
    And to prevent a file from being combined:
    // pass a boolean FALSE as the third attribute of the method
    $this->carabiner->css('wymeditor/wymeditor.js', 'wymeditor/wymeditor.pack.js', FALSE );
    You can also pass arrays (and arrays of arrays) to these methods. Like so:
    // a single array
    $this->carabiner->css( array('base.css', 'base.prod.css') );
    // an array of arrays
    $js_assets = array(
        array('dev/jquery.js', 'prod/jquery.js'),
        array('dev/jquery.ext.js', 'prod/jquery.ext.js'),
    $this->carabiner->js( $js_assets );
    To output your assets, including appropriate markup:
    // display css
    $this->carabiner->display('css');
    //display js
    $this->carabiner->display('js');
    Finally, since Carabiner won’t delete old cached files, you’ll need to clear them out manually. To do so programatically:
    // clear css cache
    $this->carabiner->empty_cache('css');
    //clear js cache
    $this->carabiner->empty_cache('js');
    // clear both
    $this->carabiner->empty_cache();
    Please let me know what you think!  If there’s something you would like changed or ad
  • #2 / Jan 28, 2009 9:30pm
    tonydewan
    I forgot to mention that a feature I would like to add is asset grouping.  That is, allowing assets to be grouped (and then combined, minified, and output in those groups).  It’s not in this version because it’s not something I’ve needed, but I’ll get to it eventually.  If you need/want that, let me know.  I could move it up on the list if there was demand for it.
  • #3 / Jan 28, 2009 11:26pm
    demogar
    This looks great dude!
    Is there any advantage over AssetLibPro?
    Thank you in advance!
  • #4 / Jan 28, 2009 11:56pm
    tonydewan
    Well, that would probably be a matter of opinion.  I looked at AssetLibPro before i built Carabiner, and there were a few things I didn’t like about it. They are:
    Use of a Config File
    I think separate config file is a little overkill in this instance.
    Unmodified CSS Tidy and JSMin
    I rather dislike the idea of including tools in my CI application that aren’t directly usable within it. Plus CSSTidy is big.  I chose to port JSMin and a CSS minification class to CI directly, and use them the ‘CI way’ within Carabiner.
    PHP Cached Files
    AssetLibPro stores it’s cached files as PHP files.  I don’t like the idea of PHP being interpreted for static assets. I also don’t like how the file reference doesn’t have a proper (js|css) extension. This is the only way to do some of the things it does (like GZIP and far-future headers), so I’m not saying it’s wrong.  I just don’t like it.
    Otherwise, the thing that I wanted most that AssetLibPro didn’t provide was the ability to do different things based on the environment.  Part of my standard CI install is an application-wide flag for development vs production environment.  Carabiner is set up using that flag, so I never have to think about it.  When I’m in development, the full scripts/stylesheets are in use, so I can easily debug, etc.  Then, when I move things to production, assets are automatically combined/minified/cached. So, to answer your question directly:
    The biggest advantage of Carabiner over AssetLibPro is the fact that it automatically reacts differently based on where you are in the development cycle.
    All that being said, AssetLibPro is really nice. There is a lot I like about it, and there’s a lot that it does that Carabiner does not (GZIP, Far-Future headers, asset grouping).  There’s a reason I listed it as inspiration!
  • #5 / Jan 29, 2009 12:07am
    demogar
    You’ve convinced me, cause I also dislike the idea of PHP files for js and css.
    I’ll give a try to Carabiner, it looks really usefull.
    I think I had a problem with AssetLibPro and CodeIgniter gzip.. is there any problem with Carabiner and CI gzip too?
  • #6 / Jan 29, 2009 12:16am
    tonydewan
    Do you mean Output Compression?  If so, I’m not sure whether there would be any problems.  I would think not, but I can’t say for sure.
  • #7 / Jan 29, 2009 12:24am
    demogar
    I’ll give a try tomorrow (it’s 23:24 here) and I let you know 😊
  • #8 / Jan 29, 2009 1:26am
    Colin Williams
    Wonderful stuff. Great addition to the framework, and definitely often requested
  • #9 / Jan 29, 2009 2:48am
    trice22
    It’s looking sweet. I’ll give it a spin.
    Any plans to include asset grouping in the future?
    —trice
  • #10 / Jan 29, 2009 6:58am
    Phil Sturgeon
    This is a pretty handy backend to the lovely syntax of my asset helper. I will be combining them and I get to keep my modular folder structure, but gain minification.
  • #11 / Jan 29, 2009 9:23am
    tonydewan
    Trice: It’s definitely on the list.  I just need to think through how to best implement it…
    Pyro: Let us know how that works for you!  I’ve not used your Asset Helper, but a quick glance makes me think that you might run into issues with caching.  Currently, Carabiner uses only one cache folder, and filenames are built based on the most recent last modified date of the files, plus an md5 hash of all of the filenames.  I’m not sure that would play nice with your helper, but I hope it works out.  Let me know if you need any illumination about how/why Carabiner does what it does.  You also might look at the two minification libraries separately.  They might be easier to hook into your helper.
  • #12 / Jan 30, 2009 7:47am
    Murodese
    Great library, thanks.
  • #13 / Jan 30, 2009 5:22pm
    freshface
    A great addition would be is to give screen or print with a css asset.
  • #14 / Feb 01, 2009 2:35am
    dannyded
    Very good library. But you have some bugs in it.
    When you try to pass array to $this->carabiner->css method, array offset error appears.
    You need to use for each function inside $this->carabiner->js and $this->carabiner->css to when you pass array. For example:
    if( is_array($dev_file) ){
            if( is_array($dev_file[0]) ){
                foreach($dev_file as $file){
                    $this->_asset('js', $file[0], $file[1], $file[2]);
            }else{
                // you are missing this part
                    $this->_asset('js', $file, $prod_file, $combine);
        }else{
            $this->_asset('js', $dev_file, $prod_file, $combine);
    One more bug is when you set combine = true false and dev = false.
    In that case, js or css file path isn’t returned correctly.
    Solution (arround line 484), you need to set $f = $f instead $f = $this->cache_uri . $f:
    } elseif(!$this->combine && $this->minify_css) { // we want to minify, but not combine
                        // minify each file, cache it, and serve it up. Oy.
                        foreach($this->css as $ref):
                            if( isset($ref['prod']) ){
                                $f = $this->style_uri . $ref['prod'];
                            } else {
                                $f = filemtime( realpath( $this->style_path . $ref['dev'] ) ) . md5($ref['dev']) . '.css';
                                if( !file_exists($this->cache_path.$f) ){
                                    $c = $this->_minify( 'css', $ref['dev'] );
                                    $this->_cache($f, $c);
                                // $f = $this->cache_uri . $f;
                                $f = $f;
  • #15 / Feb 01, 2009 6:28am
    umefarooq
    hi on windows server I’m facing the following problem. while loading js and css assets. right now im loading js but it is same for css also.
    A PHP Error was encountered
    Severity: Warning
    Message: file_get_contents(G:\umer_data\AppServ\www\dfwstatic/js/niceforms-default.css) [function.file-get-contents]: failed to open stream: No such file or directory
    Filename: libraries/carabiner.php
    Line Number: 611
