Hi…!
I’ve got a character set problem that I just can’t fix. I’m moving an EE site between servers, and everything is fine apart from euro, apostrophe and curly quote characters which aren’t displaying correctly.
I’ve followed most of the forum advice I can find, but without any luck.
- I’ve used ALTER to update the database collation from ‘latin1_swedish_ci’ to ‘utf8_general_ci’
- This matches the template encoding which is ‘charset=UTF-8’
- EEs ‘Default Character Set’ is set to ‘utf-8’
Some more info…
- When I look at the database content directly in phpMyAdmin, the characters are displayed correctly.
- When I look at the database content using Utilities/ SQL Manager / Manage Database Tables the characters are mangled
- New entries display character correctly.
Help, really, really appreciated!
