character encoding problems after migration
August 31, 2008 10:54pm
Subscribe [4]
  • #1 / Aug 31, 2008 10:54pm
    EYEWEAVER
    I’m running EE 1.6.0
    recently I moved my website to a new server, but the text encoding after the migration was wrong.
    the web site is in arabic, the encoding of the data is 8-utf.
    is there any way I can solve this issue? even if it’s a paid migration service?
  • #2 / Sep 01, 2008 1:05pm
    Hi, EYEWEAVER. Ingmar is one of our TSS team. He has the most experience in working with encoding issues. I may need to consult with him about your issue.
    What was the encoding *before* the move?
  • #3 / Sep 01, 2008 4:38pm
    EYEWEAVER
    The encoding was 8-utf
    this encoding issue with EE is really weird! it’s not affected whatsoever by the encoding I put in the html templates as if it has a mind of its own!
    I hope Ingmar can help me with this issue, otherwise I’ll have to publish all my content again from scratch!
  • #4 / Sep 01, 2008 4:48pm
    How about a link to the site?
  • #5 / Sep 01, 2008 5:04pm
    Hi Eyeweaver 😊 As Sue said, a link to the site would be most helpful. Even though the “encoding of the data” may be 8-utf” as you say, could it be that it used to be a different encoding? Also, EE 1.6.0 is very old, do you think you could upgrade to the latest version and build?
  • #6 / Sep 01, 2008 5:07pm
    EYEWEAVER
    Hi Ingmar
    the website is http://www.haridy.com
    the encoding used to be 8-utf, and u can have a look on the site on the old server on this url:
    http://www.haridy.ws
    as for upgrading, I’d rather move the site to the new server successfully first the upgrade 😊
    Thank you for your help 😊
  • #7 / Sep 01, 2008 5:21pm
    haridy.ws forwards to haridy.com/cms/ as does, haridy.com. I would be most interested in seeing the old site, though.
  • #8 / Sep 01, 2008 5:27pm
    EYEWEAVER
  • #9 / Sep 01, 2008 6:03pm
    Well, it’s like I expected:
    <meta http-equiv="Content-Type" content="text/html; charset=windows-1256">
    Your data is probably encoded with that charset. Try changing your new website to that as well.
  • #10 / Sep 01, 2008 6:13pm
    EYEWEAVER
    this code is from the old site or the new site?
    the old site is in 8-utf, but the data in the new site is in windows-1256 for a reason I don’t know!
    the problem is, the windows-1256 encoding option is not available in the control panel in EE!
  • #11 / Sep 01, 2008 6:20pm
    This is from the old site at http://www.haridy.ws/cms, where you have:
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
    ie utf-8 being commented out in favor of windows-1256. If windows-1256 is not available in EE’s control panel, you simply need to add
    to your templates.
  • #12 / Sep 01, 2008 6:40pm
    EYEWEAVER
    I did add it to the template, and it has no effect at all.. as I told you, as if EE encoding has a mind of its own!
    I even tried to over ride the encoding from the apache server configuration to force the windows-1256 encoding on all pages.. but still no effect!
    this issue happened when I first launched my web site.. every thing was fine when I was working with EE on my local machine, but once I moved it to the actual online server, I faced the encoding problem, and the only solution I found back then was to re publish all the content from scratch on the online server.
  • #13 / Sep 01, 2008 7:49pm
    EYEWEAVER, Ingmar is correct, the encoding needs to be set to windows-1256.
    How are you specifying the charset in the templates?
  • #14 / Sep 01, 2008 7:53pm
    EYEWEAVER
    well.. I’ve changed it in the template.. check http://www.haridy.com, you’ll find that the problem is still there although encoding in the html is windows-1256
  • #15 / Sep 01, 2008 9:27pm
    About the only thing I’d suggest is to reduce the template to just display the exp:weblog:entries code with the proper encoding.
    In other words, reduction testing.
